Unanswered: Push Button Starter
I think I am going to replace the push button switch with a key switch where the cigarette lighter is. Any hints??? Dave |
I am going to install one in my GT - right where the ashtray is. Here are some pics of the switch
http://www.designri.net/ |
You will either have to build a box around the ash tray in order to lift up the entire assembly or you will have to cut the tunnel to make room for all the connections.
I love cutting
i would make the key switch is really bad before i wire in a new one
on one of the cars i had the po has 3 buttons for the starter and after some rework i found the key was still good put in a otto start and way you go plus gt source can rebuild yours if its not to bad
Opeler Forever, Ben |
