Unanswered: slow or no start when hot
Any ideas? I can't go anywhere if it requires me to shut the car off, unless I plan on staying awhile! ![]() Thanks! |
Take your car to the auto. parts store and have a starter amp draw test done ( most will do these for free ) .
Check the ground cables and ing. timing ( high ing. timing will make your car hard to start ) . HTH John
Common Problem ...
ALL Opels - right through to the 1990's! - have this problem and it is usually caused by the very high current that has to pass through the switch operated by the ignition key.
Have a search for "Otto Start" to see how using a starting relay can cure this problem ... and save the hard to replace/repair ignition switch.
U-2 Driver
Try loosening up the bolt under the distributor, and then twisting it right or left to advance or retard while the car is running, listen for the jump in idle. Should crank up fine if you advance it a little, if it is retarded, it WILL NOT START WHEN HOT! This seems to be a problem with opels...most do not know how to time them right...good luck!
I had the exact problem- suffered over 2 years with it- constantly readjusting timing trying to find the sweet spot so it would start every time. Finally put in an electric fuel pump- it got better but still not perfect. Replaced the points with electronic ignition and it got even better but still not perfect. Put in an OTTOSTART and all problems are gone. Cold- it takes about 1/2 a turn to start. Hot, I pump twice on the gas and turn it over about three revolutions and it fire right up. Can't ask for much better.
