Old 12-10-2007   #1 (permalink)
hustlerzlife's Avatar
hustlerzlife is on a distinguished road
Unanswered: How much Electrical Needed to Run
The dash and gauges are out of my GT right now, but I wanted to start it up and drive it over to a local shop without having to call a tow truck or rent a trailer. The fuse box is in and the steering column is all plugged in. Does it just need the battery and that to start, run, and drive?
-Conrad (1971 GT)
Last edited by tekenaar; 12-11-2007 at 02:12 PM. Reason: Gages . . . would that be Vickie and Allen?
hustlerzlife is offline
Old 12-10-2007   #2 (permalink)
Originally Posted by hustlerzlife View Post
The dash and Gages are out of my GT right now, but I wanted to start it up and drive it over to a local shop without having to call a tow truck or rent a trailer. The fuse box is in and the steering column is all plugged in. Does it just need the battery and that to start, run, and drive?
I'd have to double check my DESTEC schematic to be sure, but I think all you should have to do is fasten the two leads from the ammeter together, and tape them up to prevent arcing and sparking. Then check out the system with the key on, then if all is O.K., start it and see if it will fire up, If it does, you should be good to go.
