Old 07-17-2008   #1 (permalink)
P.J. Romano's Avatar
Unanswered: Bosch vs. Delco Starter
I purchased new Bosch starter on eBay for my GT. It is not cranking as eagerly as Delco starter. Is there a difference between Bosch and Delco starter? Local shop believes that Bosch starter was used for 1.1 l engine. Could somebody please clarify this?
P.J. Romano is offline
Old 07-17-2008   #2 (permalink)
All of the rebuilt starters I've seen are Bosch. I believe the Delco's were used in the later model cars. As far as one being better than the other I don't know. The support brackets are different IIRC. I don't believe the 1.1 starters would even bolt up to a 1.9.
Sorry I couldn't give you a better answer.
hrcollinsjr is online now
Old 07-17-2008   #3 (permalink)
Smile For starters . . .
No power difference between Bosch and Delco starters . . . 1.1 starters have completely different mounting, won't fit CIH!
Old 07-17-2008   #4 (permalink)
I believe the difference between the Bosch and Delco are in the way the solenoids attach... as in the solenoids are not interchangeable...
Paul
Paul is offline
Old 07-17-2008   #5 (permalink)
The Bosch starter is connected to the solenoid by a braided wire with a flag terminal and the Delco has a spade type terminal that a bolt passes though to connect to the solenoid. The solenoids also attach differently to the starters as you pointed out.
Old 07-17-2008   #6 (permalink)
Exclamation Delco and Bosch CIH starters
. . . true, Bosch solenoid mounts to the starter frame by two recessed screws from the rear (flywheel side) while Delco solenoid mounts by two exposed-head screws from the front. As has been mentioned before, the starter's front mounting bracket (to engine) is also unique to each brand!
Old 07-17-2008   #7 (permalink)
Thanks everybody for the assistance. Due to slow cranking (especially when the engine was hot) I thought that Bosch starter might have less power than Delco. It must be just my "new" Bosch starter - thank you eBay!
Old 07-17-2008   #8 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
I have a Delco starter on my 73 GT. When I took it to have it rebuilt, the shop could not get a solenoid for it. So, I called Opel GT Source and Gil asked me which starter I had because it made a big difference in the solenoid used and the cost. He said the Delco cost more, a lot more. But it works great now. No problems at all. Starts fast and easy. I think he said it was only 1973 that had the Delco starter. I may be wrong about that though...
Roy Bell
1973 Opel GT
74 Manta Rallye
Concord, North Carolina
Carolina Opel Club
OMC
Ooooner is offline
Old 07-18-2008   #9 (permalink)
. . . of all the Opels I own, only my first purchased '73 GT (1976) has a Delco starter . . .
