Trouble Maker
Real Name: Tony Holcomb
Unanswered: What does your AMP Meter normally read?
Mine normally sits half way between 0 and the first bar, what would probubly be called 5 if I thought that the gauge was reliable. I still have a 35 AMP alt.
Real Name: Roy Bell
As long as it is just a "Hair" to the positive side, your system is charging. If you see it in the negative range while the engine is running, you've got a problem....
Roy Bell 1973 Opel GT 74 Manta Rallye Concord, North Carolina Carolina Opel Club OMC Last edited by tekenaar; 03-17-2009 at 05:32 PM. Reason: you got? |
![]() Provided Answers: 10
The gauge will never be at zero since there is about 4-6 amps being consumed when the engine is on. Simple way to check would be to turn everything off and start the engine. Once the battery recovers from start up, you will see a reading of just a few amps. Turn the lights on and should jump about 3/4 of the way to the charging side.
The ammeter shows just how many amps are being delivered by the alternator to your electrical system, including the battery. Both Roy and JB have it correct. As long as the engine is running, there will be a draw on the alternator, and as you turn on more electrical accessories, the ammeter will indicate a positive flow from the alternator at operating speeds. If you have everything on at idle, the alternator may go to the negative side, but with an increase in RPM it should move to the positive side of the gauge. That is normal, and once the battery has been recovered after starting, the needle will be just above the center of the gauge on the positive side. HTH.
If your Opel GT electrical system is wired the same as from the factory which would be same as the wiring diagrams in the Opel GT service manual your ampere meter only reads amperes to and from the battery. If the ampere meter is negative it means your electrical system is pulling amperes from the battery and if the ampere meter is positive you are charging the battery. Simple as that.
My ammeter just started reading negative for about 45 seconds to 1 minute after starting, then it jumps to normal, about 1/2 a bar to the positive side. This is on a 73 GT, with a fairly new alternator and regulator. Just started this, and does it each time it is started. Any thoughts?
2) Check alternator belt for tightness, but not so tight that there is no deflection on belt when you push on it (engine not running). |
