Uber Genius
I just use a rachet with 15mm shallow well socket and extensions (a six inch and 3 inch combined) to get the main bolts off and a 13mm socket with the 6" extension for the brace.
The bolts can't be removed completely using a socket, you can loosen them a few turns. Then the socket will be captured by the recess in the housing. YOU will have to finger them off. The bottom bolt requires yo lay on you back under the car to remove...
Paul |
Starter bolts
If you take the bottom bolt and brace bolt out first, you can hold the starter with one hand and ratchet the top one with the other while pulling out on the starter to keep it from be in captured. And yes you have to get under the car to remove the bottom bolt and if you don't have a lift it requires you to lay either on the floor or on a creeper to get under the car.
Socket Head Cap Screws
If I remember correctly, on my 71, 72, & 73 GT starters, I used 17 mm hex for the bolts.
For Assembly: Replaced the (2) hex bolts with socket head cap screws. Using a long allen wrench (L-shaped), I was able to spin bolts tight while supporting starter weight with other hand. Then, use open end wrench to tighten (torque) with the allen wrench. Current 71 GT has dipstick in the way of starter. Last edited by Lindsay; 05-21-2009 at 08:55 PM. |
#8 (permalink) | |
![]() Harold |
It is amazing to me how bad my memory is now. I just replaced my stock starter with the 2.4 one about 6 weeks ago and I can't remember how I went about it. I don't think I even jacked up the car, I think I did it all from the top. I know for sure the starter came out the top because it was very difficult to get out with all the extra stuff that I put on that side of the engine. I remember the socket being captured and getting PO'd that they designed it that way. I think to get the bottom bolt out I used a long extension that reached almost out to the alternator.
