Unanswered: smoke and sparks from alternator
I wouldn't mind replaced that red wire, especially since its probably fried as well, but when looking at the fuse panel there seems to be a lot of red wires and I'm not sure which one to replace. Any help on that one?? |
#2 (permalink) | |
Harold |
If there was a fuse there, then it was the worlds smallest fuse. Because I unwrapped the tape from around that wire and the connection and its just 2 separate wires spliced together...and like I said, the one was substantially smaller gauge than what heads toward the fuse panel in the car...which I have no clue where the wire ends up at in there. there's about 8 or 9 different red wires...its nuts in there!
Just to clarify, the fusible link is a wire that is designed to act like a fuse to protect the rest of the electrical system. Go to page 11 of the document below for a good explanation:
http://www.autoshop101.com/forms/hweb1.pdf Todd
Harold |
Well, thanks for that post...I just learned something! Its very possible thats what it was though. Now if thats the case and it melted to prevent a problem with an overload situation...the question then becomes what caused the overload?!? I still say that its the alternator...I mean, it has sparks coming out of the back of it when I hit the ignition! Thats definitely not normal or good....
#8 (permalink) | ||
A fusible link can't "fuse" when it is replaced with a THICKER piece of wire!
#9 (permalink) | |
So I took my alternator to a shop today and their initial reaction is that I had/have something wired wrong. I said that I was able to drive the car prior to this and that I didn't have anything wrong. But now I'm self-conscious about it...and if I maybe do/did have something wired wrong. From the battery, I just had the cable from the positive post to the solenoid. I also have 2 other connections on that bolt connection as well, but not sure what those are for. From the alternator, I just had the ground wire from the alternator to the engine block and the wire from the bolt closest to the engine block that heads in to the fuse panel.
I am curious as to how the battery gets it charge back? That question has me wondering if I have something hooked up wrong. And I'm pretty sure that I burnt up another wire from the solenoid to the fuse panel...and thats simply based on a conversation with Dennis from OGTS, since I don't have any power to the interior when the key is in the 'ON' position. (I do have a push button start by the way). Any other thoughts or suggestions?? |
So I just got done checking out the wiring...and one of the wires from the starter is completely gone! It had a fuseable link in it as well, and it was totally burned out...so I put a new one in there and a new one for the red wire from the alternator. I also checked out the voltage regulator and on of the 3 wires that goes in to the alternator is broke in two near the connector and all 3 of the wires seem to be really old and crunchy. So I think I figured out the problem. I am headed to get a new voltage regulator as we speak. I don't have the alternator back yet, but I went ahead and turned the key ON and I have power to the interior and when I tried to start it, it actually fired up! But the AMP guage was in the negative...which I think would be normal since the alternator and voltage regulator aren't hooked up. Would this be fair to assume??
#13 (permalink) | |
Gauge shows the balance of current in the system by going negative it means your using more from your reserve (battery) then the system is supplying thats all sounds normal with no alternator to me.
Opel Intern
How much is the new regulator unit? I ask because for ~$40 in parts you can get a 105amp+ alternator that is a near bolt in (I am speaking of the CS-130 unit)
#15 (permalink) | |
UFO pel abductee.
on #43 and 44 when the requirement to watch was changed from Flash 9.0 to Flash 10.0. My 'puter can't be upgraded to 10.0. Do you have any control using VIMEO on which Flash release you can use? Just wondering if anything can be done. Thanks.
#16 (permalink) | |
Opel Intern
That does require you to download the entire file and play it after it has finished, but it may be worth it!!
#17 (permalink) | |
UFO pel abductee.
![]() Thanks.
UFO pel abductee.
It worked downloading and then watching using other players.I didn't notice that option before. ![]() Thanks again.
#20 (permalink) |
So I got the alternator back today ad it had a bolt come loose on the inside of it. The voltage regulator I got, didn't match up to what i had, so I just used new wires from the alternator to the voltage regulator. With that being said, I have the 3 wires goin in to the voltage regulator, and one of the 3 (red wire) is spliced together with a blue wire with white stripes that goes to the fuse panel...what is that wire for?? Put everything back together and started it up...but the 'idiot light' is still on in the AMP meter...its showing a (-) draw...is it just because the battery was used when the alternator wasn't on? Or is something still messed up? I'd like to get it taken care of so I don't have the car die on my when I'm driving it to the trans shop tomorrow and the exhaust shop on Friday.
#21 (permalink) | |
Opel Intern
#22 (permalink) |
so does that blue and white striped wire have a fuseable link as well? dumb question, but with only 1 cable comin from the positive side of the battery (to the soleniod) how does the battery get its charge?
#23 (permalink) | |
Uber Genius
The blue and white wire should have a fusible link near the alternator (if wired properly). The battery gets its charge through a thick red wire that goes between the alternator and the fuse block to change into a red/white wire that goes to the amp guage on the dash.
#24 (permalink) |
okay, thats what i thought about the red wire. and i am guessin that the fuseable link in the blue wire is shot-g thus the lack of charge and the guage showin a negative amp reading. but that blue wire has always been connected w another wire in the voltage regulator...is this wrong??
#25 (permalink) | |
Uber Genius
