Answered: Battery Not Charging
I recently purchased a new regulator, but that was before I had it rebuilt. When I had it tested today. The guy said the alternator needs to have a ground to be able to work and I confirmed this by resting the alternator against the side wall while putting the ignition in the ON position. The amp light came on as if the system was operating properly. When I remounted the alternator. The amp light would no longer turn on when the ignition was in the ON position. So, my query is to how the alternator grounds to the body of the car. When I look at the mounts. There are rubber spacers that keep the mounts in place. So it isn't through the engine. I was thinking that it could be grounding through the regulator and if thats the case. I think I may have blown my regulator since I had it hooked up before I got it rebuilt to fix the initial problems I was having. NOTE: The car was charging prior to all of the work being done and the regulator being replaced. Sub-Note: I would put the old regulator back on, but I threw it away not thinking. So, I have made a mental note to mark any parts I think are bad and retest them later. |
Most Helpful Answer - Posted by baz
| there should be a short wire from the body of the alt that gets fastened to one of the mounting bolts , guess yours is missing or you have forgotten to attach it |
Copyright © 2003-2009 barry williams All Rights Reserved save praying to God for sunday today we pray to Nike and run like hell Last edited by tekenaar; 08-28-2009 at 10:17 AM. Reason: have forgot? |
Would you be able to identify or tell me the location of this short wire? Is it the black wire that comes off the back of the alternator that connects to a black box style piece mounted to the back of the alternator? If that is it... then I know where my problem lies and you are correct in the fact that I have reconnected the alternator incorrectly.
Thanks for your help. You have helped a great deal in resolving my problem. |
Here is a picture posted by Otto that shows the proper location and color of the ground wire. HTH Bob http://www.opelgt.com/forums/1a-star...ernator-2.html Last edited by SpringGT; 08-28-2009 at 03:59 AM. |
Sorry they are such lame questions, but I just put out $150 getting the alternator a complete rebuild. |
In the attached picture, you can see where the ground wire it attached to one of the case bolts on the alternator.
#8 (permalink) | |
#9 (permalink) | |
And if you want a really good ground, make a new longer wire and attach that to the ground wire that goes to the engine ground bolt [near the oil dip stick] and comes directly from the battery, see the photos
![]() ![]() ![]() This is a Bosch altenator, the one in Otto's photo too
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-29-2009 at 10:57 AM. Reason: Added photos & text changed the Delco part |
#11 (permalink) | |
you are right Otto, I looked in my own stock and found the same type you have and it was marked Bosch.
Those are the 35 Amp types and mine is the 45 Amp
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 08-29-2009 at 11:01 AM. |
