Unanswered: Hot start problems, help!
When this happens, the ammeter does drop down when I hit the ignition, which clearly shows power is being taken to the starter... but nothing. Sometimes the solenoid clicks, sometimes not... The car will push start, however, which is really inconvenient at times ![]() I have tried just about everything... I've replaced the main ground from the engine to the body. Ran through all the wiring in the starting system and replaced the bad connections. Last option is to replace the starter (which thankfully I have a spare!) If anyone has any suggestions before I swap the starter out, let me know Thanks, Gabe
Life without music would be a mistake. |
You are on the right track. Worn starters will act this way.
When hot, they crank slowly. If it cranks normally, then you are getting vapor lock. The gasoline vaporizes from the carb(and/or lines) under a hot hood and it will take some time for the gasoline to refill the carb. HTH Jeff
Thanks for the input. It doesn't even crank when it's hot, so I'm guessing it probably is just the starter. It is an aftermarket starter that the previous owner put on... it doesn't even look like the original!
Opel used two different starters on the 1.9. Bosch and Delco. They look different, but they both work.
Also look for the condition of the ground strap between the body frame rail and engine block on the passenger side. This EXACT think happened to me (but twenty five years ago) and when cold, the strap made a good enough connection to crank the engine, but not when hot. In my case, it was simply the bolt to the block had slightly loosened off. Removing the bolt, cleaning the strap and block surfaces and replacing the bolt cured the problem. But it took me two months and about twenty push starts to find and fix. I would intentionally park on a hill so I could push start it myself!
Good Thought Keith. Look at the simple things first!!
Install a relay in the ignition circuit. It's not unusual, for ignition switch operation to be affected by heat, and the relay will allow full power to reach the starter solenoid.
Opel GT Ignition Tips |
If you end up needing a new starter, get a new high powered one from OGTS. They crank like nobody's business. Finding remans are getting hard to do.
We'll find out...
Everyone,
Thanks for all the suggestions. I tried everything but it still wouldn't work. I don't recommend doing it in 100 degree weather in a parking lot , but I just finished replacing the starter. It fired right up without any problems. I'll find out soon if it still has problems when hot...
#13 (permalink) | |
![]() Provided Answers: 10
UngerDog
Man, 100 degrees, where could that be? It's hot here too. Then I saw that your from Fullerton. My daughter sent me a pic 2 weeks ago of a red GT with western rims at the Moonraker Apts. on Nutwood in Fullerton... just like yours. Could this have been your car?
