Starter Bracket Won’t Fit New Starter
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Starter Bracket Won’t Fit New Starter
    Member My location West Coast GT's Avatar
    Aug 2003
    San Francisco Bay Area
    2,050
    Anyone experiencing this:
    This is the second remanufactured starter from OGTS in several months. Both starters must be larger than the original starter from my ’72 GT. The bracket’s slots for the two bolts that stick out from the starter are too narrow to allow the bracket to mount.
    Also, the starter must be ½ inch longer than original, because after drilling new holes in the bracket so I could mount it to the starter, it is nowhere close to lining up with the 13mm bolt hole in the block.
    Has anyone shimmed their starter? Mine is throwing off sparks when the engine runs (I’ve got the bell housing removed so I can observe this). The teeth are just barely coming into contact with the flywheel teeth.
    Member My location BMWonly's Avatar
    Mar 2007
    Auburn, CA
    331
    Keith, it almost sounds like your starter is not all the way in. That would explain the extra length at the bracket, and not grabbing the flywheel.
    I have not bought mine at OGTS, but would expect it to be OEM size. Mine is from Kragen and fits like the old one did.
    Dieter
    Southern Red Neck My location BQS4's Avatar
    Snellville, GA
    9,235
    Gene
    Keith;
    Another thing about those brackets, not all starters are the same. I just recently got two from Rock Auto, they're shorter than the stock starter, so I left the bracket off. Both starters still work perfectly.
    UFOpel Investigator Site Supporter My location Aardvaark (R.I.P.)'s Avatar
    Aug 2007
    Des Moines, Iowa
    3,475
    Mark
    Both Delco and Bosch supplied starters and the parts are not interchangeable.
    So it seems reasonable they would be different lengths. See RockAuto for pictures of both. They physically look a bit different.
    On page 1B-10 the 1973 FSM for both the GT and Manta/Ascona comments "A new Delco Remy starter for 1973.....".
    -Mark
    '75 Manta
    Having invested my life savings into
    this Opel Manta. I expect big returns.😅
    Link to my album of Opel catalogs
    and magazine articles:
  7. #5
    Non Civilian My location opelwasp's Avatar
    Mar 2003
    Between Chico and Sac, CA
    2,030
    Not all Opels used the starter bracket. I have gone through at least 10 starters over the years. Some fit some didn't. As long as the two big bolts are in you are fine.
    1971 GT (Opelwasp)
    1974 Manta A (Polizei)
    1973 Manta A (junker)
    1973 GT (junker)
    2001 Dodge Durango SLT 4x4
    2004 Dodge Neon SXT
    2002 Suzuki SV650S
  8. #6
    Jul 2003
    San Diego, CA
    2,254
    I never had to shim a replacement GT starter.
    Some starters do not have the front bracket.
    As mentioned, there are Delco and Bosch starters.
  9. #7
    Aug 2003
    2,050
    I shimmed the starter, and abandoned the bracket this afternoon.
    It seems to have done the trick.
    The horrible grinding noise is gone when the engine is running.
    Now I can move on to reinstalling the bell housing and transmission, and getting this engine fully broken in.
  10. #8
    Jan 2003
    Chapel Hill, TN
    7,790
    Harold Collins
    Until recently I had only noticed that there were two starters used on the 1.9 engines. either Bosch or Delco. The front brackets were different and NOT interchangeable. Recently I came across a Bosch starter that was shorter than any of the Bosch starters that I had on hand and I did not have a bracket that would work on it. The starter was from a '69 GT.
  11. #9
    Aug 2007
    Des Moines, Iowa
    3,475
    Mark
    I see OGTS is also offering a permanent magnet starter for the GT. Anybody have one of these?
    -Mark
    '75 Manta
  12. #10
    Mar 2003
    2,030
    Quote Originally Posted by Aardvaark View Post
    I've got one. I haven't installed it yet, but it is supposed to be way better than the original. More power and faster starting. A must for higher displacement/compression engines.
    I'll be getting my GT back together before winter. I'll let you know how it works.
    1971 GT (Opelwasp)
    1973 GT (junker)
    2004 Dodge Neon SXT
    2002 Suzuki SV650S
  13. #11
    Mar 2007
    Auburn, CA
    331
    BMW 2002 guys do the same thing. A starter from the E30 M3 fits perfectly and cranks about twice as fast. Just did mine about 2 months ago. So a more modern Opel starter should do the same to GT's/Mantas.
  14. #12
    Plano, TX 75074
    5,297
    Otto
    until recently i had only noticed that there were two starters used on the 1.9 engines. Either Bosch or Delco. the front brackets were different and not interchangeable. recently i came across a Bosch starter that was shorter than any of the Bosch starters that i had on hand and i did not have a bracket that would work on it. The starter was from a '69 gt.
    . . . bingo! . . . bet 'shorty' Bosch had an aluminum "Bendix" housing rather than cast iron too, huh!
  15. #13
    Spofford, NH
    12,453
    Bob Legere
    It's the factory 2.4 Opel starter. OGTS bought all the remaining ones in Opel's inventory. They are VERY nice, almost exactly 1/2 the weight of a 1.9 starter, and literally twice the power. A must-have for a high compression big displacement CIH! And no issues with hot-starting....
  16. #14
    Sep 2010
    Latvia
    226
    Starter
    82' 2.0 Efi starter is same as 1.9 or like 2.4? Or different from both?
    Idea is to put that 2.4 starter on 2.0Efi engine, if it truly is lighter/more powerful.
  17. #15
    Aug 2002
    SW Missouri
    2,252
    I bought the 2.4 starter from OGTS and it is lighter and stronger.
    TMK
  18. #16
    Opeler jayhawkjesse33's Avatar
    Jul 2006
    Avon, Indiana
    540
    Eric
    Does anyone know the part#? I cant seem to find it on the OGTS website...any help would be greatly appreciated!
  19. #17
    Senior Member My location rmelchiori's Avatar
    Apr 2010
    Palos Hills, IL
    513
    Randy
    Try calling them. Their site is a little hard to navigate, but the knowledge those guys have in their heads is amazing.
  20. #18
    Sep 2010
    Latvia
    226
    Quote Originally Posted by tomking View Post
    Is 2.4starter lighter than 1.9 or 2.0? Or both?
  21. #19
    Aug 2002
    SW Missouri
    2,252
    Lighter than the 1.9. I dont know anything about a 2.0.
    TMK
  22. #20
    Plano, TX 75074
    5,297
    Otto
    Red faceIt's a 2.4 starter . . .
    Quote Originally Posted by Lesis View Post
    Is 2.4starter lighter than 1.9 or 2.0?Or both?
    . . . clear? . . . i.e. used only on the 2.4 engine, the others share the same starters.
    1. Im Looking For A 1.1 Starter
      By Rusty in forum Introductions
      Last Post: 09-18-2007, 06:18 AM
    2. Starter help for 1.9L
      By opel kid in forum 1A - Starting and Charging System
      Last Post: 12-28-2006, 09:15 AM
    3. Does anyone know? 1.6 starter to 1.9?
      By rangerrick in forum 1A - Starting and Charging System
      Last Post: 03-03-2005, 08:02 PM
    4. Starter
      By Scott McDonald in forum 1A - Starting and Charging System
      Last Post: 08-31-2004, 02:02 PM
    5. Stupid Starter (Removing the old Three-Bolt Starter)
      By Thom71GT in forum 1A - Starting and Charging System
      Last Post: 01-25-2004, 05:11 PM
