#226 (permalink) | |
#227 (permalink) |
Mark that Alt. has a res. wired in for load sensing , the Alt. I use cost a little less and I can wire in the res. to not use the warning lamp but I wanted to keep the lamp and to keep the wiring simple and close to Opel spec. HTH
John
#228 (permalink) | |
I think a got about 75 Amps for about 85 Dollars... I think you can get alot of 12SI info via google, but here is one example: http://www.alternatorparts.com/alternators_gm.htm Paul Flagstaff AZ 73 Yellow GT
