Resistor ??? or fusible link??
Results 1 to 7 of 7
Thread: Resistor ??? or fusible link??
    Nov 2005
    Dracut,MA
    345
    Marius
    Hi ,
    I am doing the wiring on my 72 Opel Gt and I am a bit confused..
    The Destec schematic shows a fusible link between the starter solenoid and the fuse box
    In a different schematic , from Easy Wire, it shows a ballast resistor.
    What do I use
    Please enlighten me, it would be appreciated
    thanks
    Aug 2006
    Goderich, Ontario Canada
    2,582
    P.J.
    It is fusible link. See the page from Opel service manual.
    Apr 2003
    Portland, Oregon
    6,324
    Fusible link.
    It's the main connection between the battery and the fuse box. It's the last line of defense if your car short circuits.
    If you ever lose complete loss of electricity in your car, and your battery connections are fine, it's likely this fusible link.
    I replaced mine with an actual replaceable fuse. When I got the car I found the fusible link blew and that's why the car had been sitting for 12 years. On Opel GTs it's really common for the headlight wires to get damaged and cause the fusible link to blow. This was the case with my current one.
    Calgary, Alberta, Canada
    4,914
    5
    You seem to be asking a question about two different topics.
    The fusible link shown delivers power from the battery to the main fuse box, and conversely delivers charge from the alternator to the battery. As described, the fusible link (and the one off the alternator) is a sort of main fuse that protects in case of a major short circuit.
    A ballast resistor has a totally different role as it provides a reduced voltage to the coil to reduce ignition point arcing. There is no ballast resistor in a stock Opel, rather it uses a resistor wire. Without overloading this thread with unnecessary details, the resistor wire may be bypassed if a coil with an internal resistor is used, such as when buying a Pertronix Ignitor and companion coil. An Easy Wire schematic might work in a North American car, but it MUST be used carefully when wiring an Opel, as there are significant differences.
    I'm back consulting, but full time now, so I have less time but more money to work on my bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT
  7. #5
    6,638
    Charles Goin
    5
    Yea.. the Easy Wiring diagrams have a few problems (Unless your talking about my diagram... at ez2wire.com then I will have to look at it).
    Ballast resistor is put inline between the fuse block and the (+) of the coil. I'm not sure it has anything to do with points. The high performance Accel or Mallory coils you can get at the local parts store require a Ballast Resistor. The use or lack there of has nothing to do with points, it has to do with the OHM rating of the Coil. A 1.5 OHM coil needs a Resistor, the 3.0 OHM coil does not need a resistor. Run a 1.5 OHM coil without a resistor and you will fry the coil. Maybe not in the short term but definately in the long term and ESPECIALLY if you leave the ignition hot without the motor running for any length of time.
    As for the fusible link at the starter or alternator, some of the Kwik Wire harnesses come with Mega Fuses instead. That way if you have a short, you pop a fuse and not burn a wire.
    CURRENT
    '74 Opel Manta - "Barbara"
    '05 Pontiac GTO
    In the past owned:
    '06 Pontiac GTO
    2 Bitters (#491/#439)
    '73 Commodore GS
    '73 Blue Max Manta Luxus
    & at least 20 other Opels
  8. #6
    Opel Addicts My location saxybiker's Avatar
    May 2002
    Tallmadge, Ohio
    2,346
    Vickie and Allen Gage
    Fusible link.
    If I were to replace the fusible link with a fuse, what size fuse would be recommended?
    Allen
    1969 GT Omi The Grandmother
    1970 GT Octavia V8 Opel
    1971 GT Opie DESTEC car
    1971 Kadett Wagon Otis Survivor
    1973 GT Olivette Awaiting Restoration
    1975 Ascona Sedan (1900) yellowOrlandoyellow
    1975 Ascona Sedan (1900) Oliver - "Olli"
    2008 SolsticeyellowOliviayellow
  9. #7
    Jul 2005
    Milner, GA.
    11,127
    Dan
    12
    Quote Originally Posted by saxybiker View Post
    Allen
    Allen
    1/3 of the peak current load over the rating.
    Now you got to remember that the fuse link is a slow blow.
    Have fun with this one.
    1. Car not starting...???!!!! (shorted wiring, blown fusible link)
      By GRS72GT in forum 2C - GT Headlamps Troubleshooting, Removal and Repair
      Last Post: 05-17-2007, 11:35 AM
    2. Fusible Links
      By maglinjosvinn in forum 1A - Starting and Charging System
      Last Post: 03-29-2006, 06:41 PM
    3. Ballast Resistor?
      By ronskydivepops in forum 1B - Ignition System
      Last Post: 02-20-2006, 12:12 PM
    4. fusible link
      By jman in forum 1E - Other Electrical/Gauges/Instrument Panel
      Last Post: 05-10-2003, 02:20 PM
