No Access
Unanswered: Murphy and starters
The warrantees (lifetime) work just great Dave. Put a new MC in the monza yesterday for free, other than the hour it took to remove, bench bleed and replace it.
Reduction ....
Dave, Sounds like you really need a reduction geared starter motor - there is a US based company that does custom starters - but they are not cheap!
If you can swing the replacement warranty thing you are probably better off with stock starters. I think that the only "stronger" starter that Opel has is the 2.4L one.
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 11-17-2005 at 01:02 AM. |
No Access
I was thinking about the bigger versions but as infrequently as I fire this one up I figured 56 bucks my cost to have one for free whenever it eats one is ok. If it were a daily driver I'd have gone a different route. Then again my Dad kinda summed it up pretty well after driving it. " if you plan on driving that every day your tags will expire before you get your liscense back" 5 year tags on it too.
No Access
I figured the starters failing was my murphys law thing, oh no just the beginning. I keep Thumper at the shop in a gated and locked environment. Yesterday I discovered somebody with an access key decided it needed a flat tire on speed rated tires, so it's sitting on the ground with what looks to be the need of a new tire and hopefully no rim damage, Today is starter arrival day so it could be fired up and did I mention snow. I see a major water burn scheduled for later today. Hold on buckle up, it's show time. I love the smell of racing fuel in the morning
No Access
The starter showed up as expected, tire wasn't cut just all the air let out. As suspected the old starter selinoid was the culprit and screwed up the armature. Best part was I was also out of gas. Which means I finally went through that full tank of 50% mix and got to go back to straight 110. Fired right up and after a darn good wheel spinning launch through 2 gears I putted on back home.
After dinner the short girl had to go for a ride. After being real persistant she went and got my Tlinket caribou racing slippers, no heel and toe driving but boy are they comfy. We putted around the block and only saw 50 but she was happy. Thumper is now home and next on the list is Fugly. |
