Real Name: Randall Stirm
Unanswered: Premature Starter Engagement
Thanks, Randy '70 and '71 Opel GT (black and red) |
Yep
Sounds very much like your key switch has "gone south" and is short circuiting allowing electricity in to the starter solenoid circuit.
There is a thread somewhere on here by "nobody" outlining how he repaired his switch - though OGTS will do the job for you on an exchange basis. http://www.opelgt.com/forums/showthr...starter+switch Get that solenoid onto the other car NOW!
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 11-24-2005 at 10:30 AM. |
Paul,
Thanks. I'll probably pick up that column sometime. As for my red Opel, I will have to do some inspecting to see if I damaged the flywheel or clutch when the starter engaged by itself! I'll give you a call when I can. Randy |
SOUNDS LIKE A JOB FOR OGTS
Jim, Thanks for the link to "Nobodys" post. I'll probably end up taking the ignition switch out of my 71 GT and sending it to OGTS. I recently bought a steering wheel puller from Unitool (item # UT7404) from a post I saw before on the forum. I know I'll have to remove the steering wheel to get to the switch. I'll have to investigate why I can't get my GT in first gear with the car running. I hope I didn't damage the clutch with the starter prematurely engaged! Randy |
I can't think of anything that would connect the two issues. How does the clutch pedel feel? Normal? Can you get it in and out of first gear with the engine off? Can you get it into 2nd gear with the engine running? Any other clues you can give us will help solve the puzzle!
Thanks,
Steve "ever notice you are never done tinkering with the GT?" Never mind, I am WAAAY beyond tinkering now...[/SIGPIC] |
