Old 08-21-2006   #1 (permalink)
AZManta's Avatar
Real Name: Tom Esterkin
Unanswered: Distributor advance
I am currently running a stock point distributor on my 2.4 FI engine with 8.7:1 compression and have some pinging at the lower RPMs in 100 plus degree weather. I'm using a pertronix pick-up to activate a perma-tune CD, and wish to keep this set-up, so I would like to keep the point distributor. On closer inspection, the centrifugal advance begins at 800 RPM, which I believe is the main cause of the pinging.
Does anyone know where I can have the distributor recurved, or is it possible to use the weights and springs out of the FI distributor?
AZManta is online now
Old 08-21-2006   #2 (permalink)
Advance ..
With your low CR of 8.7 there is something more than ignition advance wrong to get detonation ....
What Octane gas are you running 87RON or 91RON ?
Here is a good thread about 're-curving' distributors:
http://www.opelgt.com/forums/1b-igni...ibutor+springs
Though "curve" is a bit of a misnomer as the advance under control of the springs and counter weights in a conventional points distributor is closer to a straight line.
800 rpm is a bit low for advance to start - so check out if your springs are under tension when static. Loose, light springs may need replacing with a pair of stronger springs with the mounting post bent to ensure they are under slight tension at rest.
See id you can find an "Old" Motor Engineer, Hot Rodder or Circle Track racer near you with access to a distributor machine ... and the knowledge to use it!
Old 08-27-2006   #3 (permalink)
AZManta's Avatar
Smile Distributor info
GTJim,
Thanks for the info.
AZManta
