Alberta Opeler
Unanswered: pertronix again
I am starting a new thread with a new question. On my attached photo you can see the green wire that runs from the points to the coil. It splits up near the coil with the split going to an item called a Solenoid Valve Relay listed as Item 60 in the wiring diagram in the Opel Service Manual. Would I assume that I would disconnect the points wire at the 'T' and leave the remaining connection live to power the Sol Valve Relay and the Pertronix wire would be routed to its own connector? I just do not want to cause more problems down the road until I know exactly what needs to be done to ensure proper installation. |
Pertronix
Ray,
Your connections should have on 12V ignition key switched feed to the red wire of the Pertronix unit from the fuse panel. The other side of the Pertronix (black wire) should connect to the lead formerly connected to the points in the distributor (green wire) to the coil. Use the "Search" feature and "Pertronix Connections". There is a thread on it with a definitive explanation by Otto. Dave |
Alberta Opeler
Hi Dave:
I know the red wire goes up to a key activated fuse on the fuse panel rather than to the coil.....thats not my concern. Its the green wire from the points to the coil that is my issue. In my attached pic you can see the green wire and my screwdriver is pointed to the single wire that goes back to the distributor. As the green wire nears the coil you can see how it splits into two separate wires. One of the green wires from that split goes down to the Solenoid Valve Relay. I assume this SV Relay still needs to get power from its associated green wire. So when I install my Pertronix I will run the Black wire to the coil on the side of the green wire........thats easy to understand. Should I still leave the green wire also connected to the coil to power the SV Relay but disconnect the distributor part of it at the 'Y' connection? |
Otto that's what I thought too. I wonder if he's got a 73 or later carb with a solenoid shutoff on it. If so, maybe the Dreaded P.O. wired it into the coil wire as a possible lead to a relay that energizes the solenoid
Ray,
This is NOT Kadett forum specific thread, have moved to 1B - Ignition, like I did your first one.
Alberta Opeler
So when you look at my attached photo will the section of GREEN wire that goes to the Tach be attached back up to one of the connectors on the coil after I have removed the section of wire that went to the distributor? |
#8 (permalink) | |
Alberta Opeler
Hi Tek: The manual I am using is the Official GM Black Covered OPEL 1970 KADETT @ GT SERVICE MANUAL. The diagram is on Page 120-26 and listed as Figure 120-27 Wiring Diagram Kadett Rallye.
Also, I have attached a scan from this site of the area in question. You can follow the green wire to the Solenoid Relay Valve |
#11 (permalink) | |
and you would hook up the black trigger wire from the Pertronix to the connecter from which you just removed the green distributor wire. Just DO NOT connect the Pertronix red (+12V) power wire to the +/plus side of the coil!!! Power it from any other switched (turns on with key) 12V source so that you get a full 12V, not the ~9V at the coil (resistor wire), OK?
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 10-10-2006 at 05:12 PM. |
Alberta Opeler
I will hook up the RED wire at the fuse box much like I did when I hooked up my Electric Choke on the Weber 32/36. (Key on activated)
The connector thats disconnected in the photo is not a spade type but a circular type. Will I have to do a minor connector modification so I can hook up the Pertronix to it? |
#14 (permalink) | |
. . . or you can just clip your existing green disti point wire about an inch from your disconnected end, cut off the black wire female spade lug, strip both ends and splice . . . DOH
Alberta Opeler
Thanks a bunch Tek! Is it also possible for me to:
1) Hook the Pertronix Black directly to the coil. 2) Put a Spade Connector on the end of the Tach Wire and hook it to the coil also. To another connector. This would eliminate the "Y" connection that is in the photos. |
#16 (permalink) | |
Figure 64-44A shows the solenoid to be part of the mixture balance device for twin carb 11R and 11SR (1.1 OHV) OECS (Opel Emission Control System) engines offered only in '69 and '70 models . . . phew!!
Alberta Opeler
Pertronix connection and settings
70 Kadett Rallye Fuse Box
I have 6 fuses with #1 starting at the Firewall. My Weber 32 Electric Choke is connected at #3 and is key activated. What fuse connector would you recommend that I use for the Pertronix hook-up? Thanks, Ray M |
Fuse #1, #2 or #3 are all "switched 12V" off ignition switch terminal 15. Any free spade lug at any of these fuses at the top of the fuse panel (fused) is fine. I'm assuming that you hooked up your electric choke there (top) as well. You want these connections fused!
#20 (permalink) |
Alberta Opeler
Otto: The #1, 2 and 3 connectors are all used. The #3 is the easiest to access.
Can I snip the connector off of my electric choke connection and then combine the choke wire and pertronix wire on a single connector and then attach it back on the fuse spade? I noticed some of the other connections have more than one wire going in to them so I would imagine it will work. I just wanted to check with you before I cause myself some grief. Ray |
#21 (permalink) | |
#22 (permalink) |
Alberta Opeler
Hey OTTO
I had no problems wiring the Pertronix and Choke wires together and I placed them on Fuse 3.
The installation was simple and in one of my previous postings I was having a screw problem on my distributor base where the Points were located. I went with a screw the same diameter and longer. It worked fine. The Kadett started right up and ran alot smoother than it ever has before. Even my wife was impressed and when a wife is impressed with an Opel..................well...............then something went right ![]() The Dwell remains at about 54 and even with some small adjustments on the air gap it runs best at 54. Thanks to ALL who helped me along with this!!! Ray.........in the Great White North
#23 (permalink) | |
Words of caution: ONLY!! use the clear plastic 'gauge' that Pertronix includes for setting the air gap . . . this is the ideal operational gap! Wider or narrower air gap results in lower actual spark performance . . . proven by others who have tried it without success!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 10-20-2006 at 02:20 PM. Reason: clarity |
#24 (permalink) |
PiggyBack Terminals for Fuse Connections
Auto Parts Stores and RadioShack sell piggyback connectors to gang (install one or more) 1/4 inch Faston terminals to Fuse Block terminals. Even though the two wire were combined sucessfully, I still prefer to use piggyback terminals, so that I can rearrange wires at Fuse Terminal if I have to.
Lindsay 71 GT |
