Electronic Ignition Systems - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: Electronic Ignition Systems
  1. #41
    Member My location Gordy's Avatar
    Loves Park, IL (Rockford area)
    1,697
    Pertronix II and Flamethrower coil
    After reading several posts on the subject it looks like the 91847V is the proper Pertronix II set up for Opel 1.9 engines matched to a 60104 coil which Pertronix spec sheet has listed at 0.6 Ohms. 3 Ohms seemed to be the standard coil listing for the Opel engines. Can anyone verify this would be the correct components for our engines?
  3. #42
    Jul 2005
    Milner, GA.
    11,260
    Dan
    12
    If my memory is correct..coil 1.2 ohms..resistor wire 1.8 ohms.
  4. #43
    Apr 2003
    Portland, Oregon
    6,540
    1847V
    I don't know where you got the "9" from.''
    Just so you are completely informed, though, the 1847V is just the bolt in option. If you wanted to do some weird stuff, there's literally thousands of options. All you really need is a quick trigger pickup unit and the proper mechanism to trigger it.
    The Pertronix 1847V (as well as all Pertronix units, I believe) is a magnetic pickup unit. A four segmented magnet, situated where the magnet sleeve covers the lobe for the points, triggers a hall effect sensor which is converted (not converted much) to an electrical signal that triggers the coil, just like points do.
    So, if one were to get adventurous, one need only a magnetic device (similar to a Pertronix magnet sleeve) and any digital hall effect pickup unit. If one wanted to, they could search for "3144E Hall effect sensor module" on Ebay and find a simple 5v version that could, theoretically, be used to power your coil.
    But, to answer the most basic of questions.
    The Pertronix 1847V uses a standard car coil. The signal it sends is pretty much a "points" signal. It's not super special. The biggest mistake people make when installing them is to hook up the wires backwards (RED is POSITIVE)(BLACK is OUTPUTgnd) or to install them on + wire from the coil. The + wire from the coil isn't always (Opel original, for example) 12V. If it's an externally resisted coil, you will have less voltage going to the pertronix in the "run" position and it will operate or not depending on other things. Also the signal from the coil can interfere with the consistent voltage going to the Pertronix unit.
  6. #44
    Calgary, Alberta, Canada
    4,976
    5
    1847V
    The Pertronix 91847V
    PerTronix - 91847V IGNITOR II BOSCH 4 CYL
    is the newer Ignitor II version:
    "The Ignitor II has many of the same great feature that the Ignitor has, but its smarter. Ignitor II units sense the coil current level and use a powerful micro controller to adjust the dwell. Variable dwell helps to maintain peak energy throughout the entire RPM range. Features Ignitor II systems develop up to 4 times more energy between 3000 and 5000 RPM than standard ignition systems. High RPM performance is improved when used with the Flame-Thrower II super low resistance (0.6 ohms) 45,000 volt coil. • Adaptive dwell maintains peak energy throughout the entire RPM range, reducing misfires while improving engine performance. • Develops on average 4 times more available energy between 3000 and 5000 RPM, and 2 times more available plug voltage. • Peak current level is reached just prior to spark for maximum energy without the heat build-up, increasing coil and module life. • Adjusts spark timing at higher RPMs to compensate for the inherent electronic delay. • Senses startup and develops more energy for quicker, easier starting. Built in reverse polarity and over current protection shuts down the system, preventing component damage."
    As for the correct wiring, FO1981 hit the main issue on the head: The Ignitor (I or II) has to be powered by a non-resistored (full 13.6 to 14.4 volt) supply, NOT by the stock Opel resistor wire that supplies power to the coil.
    The Ignitor I REQUIRES a 3 ohm (internal resistor) coil, if the coil is supplied with a non-resistor supply; OR the coil can be a low resistance type if the power supply to the coil is resistored, either the stock resistor wire, or an aftermarket ballast resistor. But in either case, the Pertronix itself MUST be powered with a non-resistored power supply.
    As for the Ignitor II, it seems that it can use (and provides better high RPM spark) with a non-resistored coil. I suspect that the variable dwell feature allows the coil to provide maximum spark voltage without over-saturating and overheating.
    Working on the bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT, and may have another GT to build next...
  7. #45
    Apr 2003
    Portland, Oregon
    6,540
    I learned something new today.
    (either way they are WAY overpriced considering the components they are made with - peeve)
  8. #46
    Jan 2003
    Chapel Hill, TN
    7,790
    Harold Collins
    1. Accufire electronic ignition?
      By ungermm in forum 1B - Ignition System
      Last Post: 05-06-2016, 05:52 PM
    2. Electronic Ignition Map
      By greenbarron in forum 1B - Ignition System
      Last Post: 03-20-2006, 08:30 PM
    3. Replies: 3
      Last Post: 01-03-2006, 01:50 AM
    4. Electronic Ignition
      By shaggy in forum 1B - Ignition System
      Last Post: 02-23-2005, 10:22 AM
