Old 11-12-2007   #1 (permalink)
azopelnut's Avatar
azopelnut
Unanswered: Fried Ignition??
Last Saturday I had intentions to get out my 73 GT.
This is what I did:
Step 1-remove good battery from the 75 Sportwagon
Step 2- install good battery in 73 GT
Step 3- receive phone call and a 30+ minute distraction
Step 4- return to the GT and become horrified by the fact that the key was left in the on position
Step5- attempt to start ....nothing
Step 6- inspect battery cables
Step 7- attempt to start....cranks twice
Step 8- prime fuel pump and attempt to start ...nothing
Step 9- return battery to 75 Sportwagon which faithfully started on the firs attempt
Step 10- post this question on www.opelgt.com
Did I fry the GT ignition?
Is there a conclusive way to verify?
Paul "azopelnut" Heebink
1970 GT 12A-Rotary 5-speed
1972 GT 2.0, 5-speed
1974 Manta, 1.9 Auto A/C
1975 Fiat X19
azopelnut is offline
Old 11-12-2007   #2 (permalink)
neuropel's Avatar
Still running points?
-Abraham Lincoln
________________
1972 GT 2.4L
1974 Manta GT/E 2.2L
1973 Manta Rallye 2.5L
neuropel is offline
Old 11-12-2007   #3 (permalink)
azopelnut's Avatar
azopelnut
I am running pertronix
1975 Fiat X19
Old 11-12-2007   #4 (permalink)
neuropel's Avatar
I'd try swapping ignition parts over from the ascona just to test. Then you'll know. I don't know if the "key left on" situation would be detrimental to the pertronix unit or not, but I have heard of people frying points when leaving the switch on.
Hey, this is a reason why it's good to have multiple Opels!
Todd
-Abraham Lincoln
________________
1972 GT 2.4L
neuropel is offline
Old 11-12-2007   #5 (permalink)
jlthunder's Avatar
Follow the suggestions mentioned in the previous posts.
To answer your question. Look at Question # 7 in the instructions.
http://www.opelgt.com/photos/showphoto.php/photo/2256
This was located via the search engine under "petronix instructions"
You may of fried the unit.
1973 GT, Parted out, R.I.P.
jlthunder is offline
Old 11-12-2007   #6 (permalink)
101st Airborne Vet V.N.
MICAH1's Avatar
Real Name: Thomas Johnson
MICAH1
Answer.....
Paul, If you have not figured it out by now, your answer is time to purchase a new pertronix set. I had a first hand experience with that... welcome to the club. Keep a extra set.
Thomas
MICAH1 is offline
Old 11-12-2007   #7 (permalink)
Mike's Opel Shop
opellane's Avatar
Check Ignition coil
You might of just fryed the Ignition Coil, check to see if coil ohm's out first.
or if the resistor wire or ballest is burnt, and voltage at pos side of coil.
I always have an extra set of pertronx in the car, and an extra clutch cable clip for thoses emergency too. Hope that some helps and good luck.
Mike
MIKE
1969 Opel GT in Paint Shop
1973 MGB, Red, Weber 38DGES
I have pride in my rides
opellane is offline
Old 11-13-2007   #8 (permalink)
baronbors's Avatar
baronbors
Your timing couldn't have been better as BugStuff usually has a Thanksgiving sale on the Pertronix.
baronbors is offline
Old 11-13-2007   #9 (permalink)
opelwasp's Avatar
Pertronix are very sensitive to continued application of voltage. I burned 3 till I figured out they dont like to be hooked up when charging the battery or hangin with the guys with the stereo blasting.
opelwasp is offline
