Unanswered: Engine Dies: Electrical? Mechanical?
Are you saying both the tachometer and speedometer go to zero when this happens?
My first guess would be a failing ignition switch but the speedo is cable driven. How about giving us some more clues into your problem.
Tinkering is my name..fun is the game |
Ignition Switch?
Sounds like you may have poor isolation within your ignition switch.
(This is commonly caused by excessive carbon, or wear, within the switch) You can check for this with an ohmmeter, using procedures described in the FREE Acrobat-format download, within the date field of April 2006, at: Opel GT Ignition Tips Steering column disassembly is described here: Electrical System If so, that means the switch needs to be either cleaned or rebuilt. Last edited by Anonymous D; 01-25-2008 at 09:04 PM. |
the car wont accelerate at all its like its died but when im coasting i turn the key to start it up and then the starter grinds. i do this cuz im 16 and im scared someone is gonna rearend my baby lol, instinct kicks in. with my bad luck always happens when im in the middle of traffic and just started to go off a red light.
I was going to ask you to do a voltage drop test across the red and black wires..that was until I looked at my GT and saw how dangerously close they are to the steering column.
The more safer route would be to use Anonymous D's post.
Tinkering is my name..fun is the game Last edited by wrench459; 01-26-2008 at 10:40 PM. Reason: Grammar |
i think i found the problem. today i was changing the oil and noticed on my coil that one of the bolts were stripped that hold one of the metal peices that hold wiring on was VERY loosed. so i put a smaller nut on and now its tighter. i dont know if that fixed it cuz it just so happens my master cylinder went out when i was bleeding on the brakes today. now i gotta get a new master cylinder and put it on then drive the car and see if it "turns off" again. so ill let you know in a couple of days if that was it. in the mean time the opel is gonna be parked. till i get a new master cylinder.
Moderator Note: No less than THREE topics in the thread this originated from. Posts split off to new threads regarding brake master cylinder and classic insurance
Keith Wilford working on my '71 GT and '75 SportWagon Last edited by kwilford; 01-27-2008 at 02:49 AM. |
#14 (permalink) | |
I have an extra coil in good condition if you want to give it a try. --Bruce
If it's not leaking oil - it's out of oil! 1969 Opel GT ... visit my restoration project ... 2008 SRT4
Bruce you live in missouri right? if you do maybe we should meet up sometime. But I have a extra coil i dont know if its good. Tony P said it looked fine when he came over last saturday. I gotta wait for the brakes to come in then drive the car around to see if that loose bolt was the problem.
Lewis
#16 (permalink) | |
I live right around the corner from you in South County - just a few miles south of the mall. I would definitely like to meet up sometime - I just need to wrap up a bathroom remodel first. My car had a few starting issues and several gauges not working properly. I took apart most of the wires and connectors that were suspect and thoroughly cleaned all of the oxidized connections with a Dremel equipped with a stainless steel brush (did the same during the install of the Crane Cams XR700 and PS20 coil). I usually slop on a little dielectric grease for good measure when reconnecting. --Bruce
thanks for the tips. well when you get done with your bathroom and have a freeday just give me a call 636-544-4281
Ok im pretty sure the problem is my ignition switch. i jiggle my key and sometimes my car runs like a champ and sometimes i just sputter around. i just need to know of a place that will rebuild it or sell me a new or rebuilt one?
#20 (permalink) |
intermittent ignition
Many moons ago I had a '51 Ford that would go and stop at its pleasure, of course, while I was in traffic. I found a loose wire on the coil. Perhaps that is what you found before the MC problem arose. OGTS does rework ignition switches, but my rework didn't last long. I'm going to try a push button starter switch rather than rely of the ignition switch. Yes, I do have an Otto start relay and highly recommend them.
Denny |
