#26 (permalink) | |
GTer
Real Name: Patrick
. My car is equipped with the original blue Bosch coil.Patrick
Definitely EX-member of the MWTE! © Mr. Corey Suggs |
#27 (permalink) | |
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-15-2008 at 02:47 PM. |
#28 (permalink) | |
GTer
Real Name: Patrick
For a picture of my coil see: Under the hood 2 - Opel Photo Gallery
#29 (permalink) | ||
#30 (permalink) | |
Opel would NOT intentionally connect an internal resistance coil, like the Bosch "blue coil", to an "external resistance" power wire, further dropping the start voltage to ~9V and the actual "run" voltage to only ~6V! . . . totally defeating their original "ignition voltage boost during start" design, as already stated in a previous post here.. . . and, looking at your picture, can't really tell if there are two wires at the coil's + terminal, but the female-spade connector at one of the connections (tach/e-trigger?) is definitely NOT original! . . . that side typically had a round "bullet" type connector and green wire(s).
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-15-2008 at 04:38 PM. |
#31 (permalink) | |
GTer
Real Name: Patrick
at the 12V (+/15) side a black one and a clear one (with the Hot Spark ignition also a red one). and at the "-" side a green one and a black one from the H-S. Looking at the wrapping of the cables, all authentic.
Definitely EX-member of the MWTE! © Mr. Corey Suggs Last edited by tekenaar; 09-15-2008 at 05:26 PM. |
#32 (permalink) | ||
Both e-trigger and blue coil + connection only have a full +12V applied during starting! During "RUN" condition, there is only +9V applied by the resistance wire to the e-trigger and blue coil + terminal! So, because blue coil is internal resistor type, the coil actually only sees +9V during "Start" and ~+6V during "RUN" . . . i.e. no ignition voltage boost at "Start", only 67% (+9V) of the designed "Run" voltage at the + terminal (only 50% (+6V) used at the coil) and coil being triggered by e-trigger running at 75% (+9V) of the designed voltage level! . . . none of these are GOOD!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-16-2008 at 12:15 PM. |
#33 (permalink) | |
GTer
Real Name: Patrick
.I read this thread a few times but I can't figure out how to connect my blue coil and H-S ignition. If I understand well mine is hooked up wrong. Sorry that I don't understand, but I'm not that technical (especially electronics) and since English is not my native language... ![]() Please tekenaar help me out before I blow up my H-S and coil. Patrick
Definitely EX-member of the MWTE! © Mr. Corey Suggs Last edited by tekenaar; 09-16-2008 at 12:14 PM. |
#34 (permalink) |
Patrick als de voltage lager is dan het moet zijn zal je de H-S en bobine niet opblazen. Uit de uitleg van Otto heb ik dit begrepen:
Als je een Blauwe Bosch bobine hebt, dan heeft deze een extra inwendige weerstand, omdat de originele draden uit de kabelboom zijn gebruikt krijgt jou bobine en ontstekings module, door de weerstands draad [de draad met doorzichtige isolatie] nu minder spanning, niet dat dit zo heel erg is, maar je vonk is hier door ook minder, het beste zou zijn als je een geschakelde [dus door de contact slot geschakelde] 12 VDC naar de bobine en ontstekings module brengt, en de ander twee draden los haalt en aftape met isolatietape zodat ze geen sluiting kunnen maken, verdere draden zijn dan goed.
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 09-16-2008 at 05:03 PM. Reason: extra explanation in Dutch |
#35 (permalink) | |||
![]() First column is stock coil, or any non-resistor coil - i.e. Bosch red coil, correctly connected and triggered by points or correctly wired e-trigger with all relevant voltages listed . . . Second column is Bosch blue coil, or any internal resistance coil, correctly connected and triggered by points or correctly wired e-trigger with all relevant voltages listed . . . note that the coil does not get a voltage boost during 'start'! Third column is commonly, but incorrectly, wired Bosch blue coil and incorrectly wired e-trigger . . . e-trigger is powered by only +9V (75% design voltage) during 'key on/run' condition and ignition is further hampered by coil's +6V (50%) actual operating voltage, regardless of trigger method used! This is what I meant by, " . . . none of these are good!". . . alles nu verstaan? . . . everything now understood?
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 12-27-2008 at 03:24 PM. |
#36 (permalink) |
'72 Opel GT (Sara)
So, if the electronic ignition module begins to "fail" causing the car to misfire, does that also mean the mechanical fuel pump driven off the distributor drive shaft would also begin to fail to pump enough fuel to the carb? In other words, is it possible that failure of the ignition module can also lead to fuel starvation as a secondary problem? It seems logical but not sure...maybe a stupid question
. I'm just trying to build a complete picture here of the sequence of events.
#37 (permalink) | |
Above and beyond all that, the engine runs off a small puddle of fuel inside the carb being drawn in by engine vacuum through a metered hole. Basically a controlled leak from a small cup. That cup holds enough fuel for the engine to run for several seconds and it's level is replenished by the fuel pump. A noticable failure of the ignition module would be on the order of individual engine revolutions, a very small portion of a second, by comparison.
#38 (permalink) |
GTer
Real Name: Patrick
Thanks for the info Otto
. Tomorrow I'll check the wiring and voltages. However before you posted this excellent diagram I measured the voltage of the coil with the engine running: between "15" and ground I measured 13V ; between "-" and ground I measured 11.5V. Does this tell you anything already?
#39 (permalink) | |
BTW . . . automotive electrical voltage is typically referred to as 12V, even though, when the engine is running, it should measure 13.3-13.8V on older cars and up to ~14.6V or so on newer cars with higher amp, electronically (rather than electro-mechanically) regulated alternators. Oh yes, the actual voltage used to charge the coil cannot be measured externally on "internal resistance" coils because the "resistor" is physically connected between the coil's + post and the primary winding of the coil . . . actually a "step-up" transformer.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 12-05-2008 at 12:47 PM. Reason: add info about ir-coils |
#40 (permalink) |
'72 Opel GT (Sara)
Makes sense - thanks!
#41 (permalink) | |
GTer
Real Name: Patrick
Another satisfied customer of OpelGT.com !
Definitely EX-member of the MWTE! © Mr. Corey Suggs Last edited by tekenaar; 09-20-2008 at 01:58 PM. |
#42 (permalink) | |
#43 (permalink) | ||
I went back and added the coil secondary ignition voltages (bobine hoge spanning) which fires the plugs. This directly shows how much a few volts more or less at the coil primary + connection affect the secondary high voltage that fires the plugs! The lower two illustrations in the third column, the way you had it connected originally, Patrick, show that you were not only firing your plugs with only 2/3 (8KV) the designed spark output of the coil (12KV), but were also triggering the coil with only 3/4 (+9V) of the designed e-trigger voltage (+12V)! ![]() Anyway, glad it helped make things a little clearer for you, Patrick, and now Erick can fully explain it to anyone there . . . and in Dutch!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-19-2008 at 11:23 AM. |
#45 (permalink) | |
#47 (permalink) |
ok folks a follow up: I received my new replacement ignition kit from hot spark today, part no. 3BOS4U1. Took me about 5 minutes - installed, set timing, done.
This newer replacement I received was wonderful. It stands a bit taller, so I could not use the original dust cover that goes inside under the rotor. No gap to set, it mounts rigid on the pin out of distributor with one screw, exactly like the original points did. You just put it in and, according to hot spark, the resistive wire makes no difference, so I left mine in. I read the post about the resistive wire and voltages and all that, but this is using the original set up and with resistive wire, module works just fine as far as the 12 volts at the distributor coil - well the car ran fine with the points and all this does is eliminate them - so as long as it fires, voltage is of no concern. The upside . . . no maintenance and it idles excellently compared to mechanical points. buy it, install it, change nothing, except maybe timing, and be done with it.
#48 (permalink) | |
![]() . . . oh, beg to differ, but it does! The Hot-Spark module is a direct copy of the Pertronix unit, designed and patented to run on a full +12V! Will the Pertronix/Hot-Spark trigger function at +9V? . . . absolutely, just not with the designed trigger performance and, likely, its designed-in reliability factor! The Pertronix patent lapsed allowing Hot-Spark to copy it verbatim without requiring licensing fee payments. It is the sole reason Hot-Spark can offer it at a discounted price - no R&D costs, just manufacturing. It is also the reason why they wouldn't redesign it to trigger at the same performance level at +9V! No matter how you slice it, if you operate either trigger at +9V, you're getting only 75% performance and efficiency and you're just not taking full advantage of your decision to change to electronic triggering in the first place. All of that said, are you using a "stock" or "non-IR" coil or any aftermarket "IR" (internal resistance) coil with your coil's "stock" R-wiring? All of the things pointed out in my third column blue coil wiring diagrams still apply, no matter what Hot-Spark claims!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-21-2008 at 01:45 PM. |
#49 (permalink) | |
#50 (permalink) |
Well, you missed the point entirely, but, it's your car, run it the way you want . . . the consequences will be yours too, after all.
. . . still interested in seeing a pic of your particular installed unit, Dennis, if you'd care to share with the rest of us . . . the mounting method appears to be a bit different from rest.
