Electronic Ignition Question - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 77 of 77
Like Tree1Likes
Thread: Electronic Ignition Question
  1. #61
    Member My location Dennis Texas's Avatar
    Oct 2006
    Texas
    382
    Just wanted to add a follow up... after getting the correct electronic module in place ( be sure the module matches the coil you are using or ask Hot Spark for recommendations they are very responsive to emails), the car has run excellent for 2000 miles now I did get wrong module in the first installation but after correcting and driving it I believe this is one of the best things you can do to improve reliability of the opel ignition for just under 40 bucks (not much more than an original replacement set of points and condenser and it bolts right on. )
    If everything seems to be going well you have obviously overlooked something.:banghead:
  3. #62
    Opeler JAson Barkmeier's Avatar
    Nov 2007
    South Dakota
    8
    Opled' to work today. Got the timing set right still running pretty good with the replacement hot spark mod. I am still running with the clear resistor wire in place and IR coil. I will take time to test a direct wire feed for a few weeks and see if it changes performance at all.
    Barky
  4. #63
    Opel Intern Swiftus's Avatar
    Aug 2008
    Corvallis, Oregon
    1,205
    Jay Swift
    Goedzo, Erick, dat is het precies . . . well done, Erick, that's it exactly . . . Patrick, maybe this will help a bit more . . . misschien zal dit nog wel een beetje meer helpen . . .
    First column is stock coil, or any non-resistor coil - i.e. Bosch red coil, correctly connected and triggered by points or correctly wired e-trigger with all relevant voltages listed . . .
    Second column is Bosch blue coil, or any internal resistance coil, correctly connected and triggered by points or correctly wired e-trigger with all relevant voltages listed . . . note that the coil does not get a voltage boost during 'start'!
    Third column is commonly, but incorrectly, wired Bosch blue coil and incorrectly wired e-trigger . . . e-trigger is powered by only +9V (75% design voltage) during 'key on/run' condition and ignition is further hampered by coil's +6V (50%) actual operating voltage, regardless of trigger method used!
    This is what I meant by, " . . . none of these are good!"
    . . . alles nu verstaan? . . . everything now understood?
    Ok, I just want to check BEFORE I turn the key. I have a Flamethrower 3 ohm internal resistance coil and an Ignitor I. Is this okay so far?
    I connect the BLACK wire from the Ignitor to the negative (-) terminal on the coil.
    I connect the RED wire from the Ignitor to the positive (+) terminal on the coil.
    I connect the GREEN wire from the tachometer to the negative (-) terminal on the coil.
    I connect the BLACK wire from the starter to the positive (+) terminal on the coil.
    Finally, because I have an internally resisted coil, I replace the clear resistor wire with a normal wire and connect that to the positive (+) terminal on the coil.
    Any objections?
    TIA,
    Jay
  6. #64
    Plano, TX 75074
    5,299
    Otto
    Thumbs upThat's it . . . exactly!
    Quote Originally Posted by Redskinsjbs View Post
    Any objections?
    TIA,
    Jay
    Yes . . . BEFORE I turn the key.
    Yes . . . BLACK wire from the Ignitor.
    Yes . . . RED wire from the Ignitor.
    Yes . . . GREEN wire.
    Yes . . . BLACK wire from the starter.
    Yes . . . replace the clear resistor wire with a normal wire.
  7. #65
    Aug 2008
    Corvallis, Oregon
    1,205
    Jay Swift
    Shweeeeeeeeet! Lets go crank this puppy!
  8. #66
    intx73gt
    Feb 2009
    livingston tx
    34
    tom kaye
    Hot Spark
    Last November when I flew to Billings to pick up my newly purchased, on e-bay 73 GT Was not aware of the diffrent brands of electronic ign.modules so spent $40 and got the Hot Spark System along with one of their coils they recomended,was an easy purchase since it was listed on e-bay in the opel GT category.Now 8000 miles later the unit is still performing perfectlly without any problem whatsover.
    but now Ive got myself convinced that I cannot live without a compufire system,So will be doing the upgrade the first week of November.
    Will be posting photos soon of your Texas Opelers Fall meet that is comeing up October 23rd,24th and 25th.We will all be getting together in the Lake Livingston area,we are only about a 2.5 hour drive from the Louisiana border so if any of our neighdors would like to join use give me a shout.
    tom kaye
    tcavk@yahoo.com
  9. #67
    Opeler lowkey's Avatar
    Oct 2003
    Dallas, Texas
    1,742
    James
    13
    About the Hot Spark
    Two things:
    1. I met the guy who sells them, he lives here in Austin, and his Fulltime job is driving a Cab. Nice enough fellow, but definitely not a "Car Guy."
    2. Don't ever Jump Start, with a Pertronix, or Hot Spark. Instant fry, trust me.
    If you have a dead battery, either charge it, or hook up the jumper cables, let the donor car run for a while until the dead car is charged up, then disconnect the cables, and start the dead car. If you try to do a regular Jump Start, you'll probably fry the Pertronix/Hot Spark unit.
    I don't know exactly why, but from personal experience, it's a good way to fry it.
    Everything else I read here is spot on.
    I'm just another Opel Rehab Failure.
  10. #68
    Member opeljohn's Avatar
    Sep 2003
    Springfield IL
    1,207
    bump this up
  11. #69
    Jul 2016
    USA
    7
    coil/pertronix wiring check
    Here's what I have and I wanted to check it:
    72 GT, Pertronix ignition, Blue Bosch coil with internal resistor
    On #1 (-) side of coil: Green wire to ground at engine block, Red (that's all I had at the time) wire to tach., Black wire to distributor.
    On the #15 (+) side of coil: Red wire to distributor, black wire to starter solenoid, Red wire to fuse block (it replaced the clear resistance wire).
    What is drawn as a red jumper wire on your diagram on the #15 side does not exist, it's just representing that this is what the three pronged terminal or the coil does?
    It does not matter which connectors go on which part of the three pronged terminal, correct?
  12. #70
    Apr 2003
    Portland, Oregon
    6,666
    Quote Originally Posted by BDD1 View Post
    What three pronged terminal?
    The - side of coil does NOT ground to the block. It connects to the black wire coming from the pertronix.
  13. #71
    Jul 2016
    USA
    7
    The spade terminals on each side of the coil each have three "tabs". Don't Tekenaar's diagrams each show a green wire going from the coil to ground on the #1 (-) side?
    Also, in the central diagrams what does the red "jumper wire" really represent? I doubt it is an actual wire.
  14. #72
    Plano, TX 75074
    5,299
    Otto
    IR (internal resistance) coil!
    IR coils have resistance between coil +side and coil primary inside, reducing the actual voltage 'seen' by the coil. When you hook up the +12V resistance wire to the +side of the coil, you're adding another resistance, further reducing the voltage 'seen' by the coil. The "bypass wire" is there to eliminate that second resistance!
    Oh, and the "ground side" of the coil is more properly called the "trigger side" . . . when using the original distributor points: points closed (grounded), coil hi-voltage secondary is charged to full voltage; points open and coil secondary charge field collapses and fires plug at the rotor position. E-triggers just do that electronically without changes over time like points. Clear now? HTH
  15. #73
    Jul 2016
    USA
    7
    But Otto....I can clearly see a green wire in your diagrams that go from the (-) side of the coil to a ground symbol....even though it says "pts" near that wire....which I didn't think was defined. I removed that wire and the car started right up like it used to.
    I have a pertronix ignition and only have a red and a black wire from the distributor to the coil. I replaced the clear resistance wire with a heavy gauge red wire when I installed the pertronix system.
    How does red bypass wire get connected? My three terminals on the (+) side of the coil are completely taken up by the red pertronix wire, red replacement for the former resistance wire, and the black wire to the starter solenoid.
    Is there a clear photo of the coil showing every wire to each side including tach. and ignition switch wire? There is a photo in another pertronix or coil related thread but it is so blurry it could be a pic of a UFO.....or maybe even Bigfoot.
  16. #74
    Apr 2003
    Portland, Oregon
    6,666
    Dude, forget the diagram and I will explain all you need to know with a Pertronix on YOUR car.
    Black wire from the Pertronix goes to the - side of the coil.
    Green tach wire (in your case red because it's all you had) goes to the - side of the coil.
    Red wire from the pertronix goes to the + side of the coil and another wire (that used to be the clearish wire) goes to the fusebox on the ignition controlled side.
    Forget three spade doohickies on the coil. They mean nothing other than it used to have three wires attached to it. That's in the past. You know, the past is supposed to be in the past. Not dragged up like you forgot an anniversary or something. Let the three spade thingie go already.
  17. #75
    Jul 2016
    USA
    7
    Well alrighty then. That's how mine is hooked up and it starts like a champ. I see your :P and raise you a :P.
  18. #76
    Mike's Opel Shop Site Supporter My location opellane's Avatar
    Apr 2004
    Goshen,New York
    908
    Trouble-shooting Pertronix
    How do you know if you Burnt out your Pertronix ??/
    well I've been working with them a while..
    First off you can never leave the key switch to On Position ( like to listen to Radio or if the engine stalls) This will burn out the coil and then the Pertronix so make sure you key her off.
    Ok first off a 1.5 ohm coil will use the stock clear wire (+) fusebox
    a 3 ohm coil will use a new red wire from fusebox installed
    If you think you burnt out your coil...it will get real hot Ohm read it! with nothing wires attach If OL or infinite , Zero ...no reading...it's N/G
    If it reads 1.5...If it read 3,0 ohms the coils is still good
    Now the pertronix it has a diode in the circuit so when you ohm the two pertronix wires will only ring though one direction (+ red) to (- bk) and nothing the other direction, OL infinite reading then Pertronix is still Good and should work
    when cranking engine you must have 12- 13.7 volts on the coil..not 11.5 will not start
    These are just some trouble shooting tips that I ran across that I'd thought would share...good luck Guys
    MIKE
    1973 MGB, Red, Weber 38DG
  19. #77
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Oil filled ignition coils likes around four amps flowing in the primary circuit.
    1. Electronic Ignition Systems
      By tomking in forum 1B - Ignition System
      Last Post: 05-07-2017, 01:20 PM
    2. electronic ignition on ebay
      By free4u2nv in forum General Discussions
      Last Post: 03-09-2008, 10:00 PM
    3. Electronic Ignition Map
      By greenbarron in forum 1B - Ignition System
      Last Post: 03-20-2006, 08:30 PM
    4. Electronic Ignition
      By shaggy in forum 1B - Ignition System
      Last Post: 02-23-2005, 10:22 AM
