Unanswered: Electronic Ignition Question
I just installed the Pertronix 1847V electronic ignition on a 1973 opel GT. I can't get over the difference and plan to replace the carburetor with a Weber 32/36 next. I noticed there is a tapping sound coming from the distributor and was wondering if this is normal or did I install it incorrectly. The car did not have any tapping sound before. When I race the engine (I haven't begun driving the car on a regular basis yet) the tapping sound increases a bit more.
I appreciate all advice, Thank you, Kappy |
#3 (permalink) | |
I had the pertronix on my car for a little over a month and was amazed at the difference it made over my points. Unfortunately, I just had to remove it and replace it with points once again. After the engine would warm up, it would miss and backfire-then die. After the engine would cool down, it would run fine again. I replaced the coil and plugs, checked my choke, and searched for vacuum leaks with no luck. I'd read in the forums how reliable the pertronix systems were-so that was the last thing I checked. Put the points back in and problems went away. I miss the electronic ignition, but having points beats pushing the car-even a lightweight GT. Does anyone know of a more reliable electric ignition?
I'm using the Crane Cams XR7000 Points-to-Electronic conversion kit from Summit Racing. I've also swapped to their coil as I like to keep components of the same brand together for compatibility sake.
Rather than order from their catalog or online, I recommend calling their number and let them help choose the correct model. 800-230-3030. The only problem I had was a bad electrical connection (that I caused) during my 1700 mile trip to the Tacoma Gathering last month. BTW, I carry backup points, condenser, cap, rotor, spark plugs, and plug wires in my on-board backup stash. |
Have you run a separate wire for 12v sw as stated in post #6? You have to eliminate the original resistor wire. I used a pertronix previously, installed per instructions, and had not one problem. I've since changed to a compu-fire. Not due to a problem with the pertronix but it seemed it might be more reliable as you eliminate the cap and rotor but it is also more expensive (~4x).
#9 (permalink) | |
I don't get it . . .
. . . I own six of them installed in various Opel models with different distributors and have not had a single problem, ever, with any of them, my first since May 1978 . . . Perlux then! . . . I don't get it?
'72 Opel GT (Sara)
So, does anyone know if these electronic ignitions (Pertronix., Hot Spark, etc.) are in fact heat sensitive such that they can start to misfire or "shut down" after prolonged exposure to high under hood temperatures? I'm just curious if some presumed vapor lock / fuel delivery issues may actually be issues with the electronic ignition.
'72 Opel GT (Fireglow Orange)
Third Owner, Purchased in 1986 Current Status: Fully Restored Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, XM Radio / CD, ADDCO Front / Rear Anti-Sway-Bars Other Cars: '06 Pontiac Solstice (Envious Green) '99 Oldsmobile Intrigue GLS (Black Onyx) |
mine is a hot spark not a pertronix brand name. Yes I have run with and without the additional resistor I had trouble in the beginning but I finally added the resistor back in and it worked great and still does when cold. It is after about 10 miles of driving temperature gauge in the middle of the range no over heating problems but the module fails. I never I had a problem after installation because I only cranked it up briefly and let idle in the yard or went around the block. When I got my car inspected and using it for the daily driver is when the problem appeared. It is not a fuel problem, changing back to mechanical points corrected everything and I drive it about 40 miles a day now. I wrote the manufacturer about the problem, I have 4 of these units and it's going to fail I need to send them all back or find another way to install them, waiting on the manufacturer to write back they are closed today.
I've mentioned before that my ignition unit is a Motorola, that's what it says on the ignition box which resembles a Ford unit. It was found on that cherry little '69 Kadet we "stole" and used for parts.
I think it's an awesome setup. Puts out a fat blue spark that will jump all the way across my marine spark tester. Scary! I wish I knew more about it, and where to get more, all I know is that's what I would want on a street car. In the class I raced my GT in, full of Fords that have ignition trouble a LOT, mine just purred and never skipped a beat. Always fired up instantly, too! Has anyone else ever seen or used this ignition? I'm still toying with the thought of prepping the car to run in Spokane's Outlaw Compact races. They have invited me join the fun, know what my car is and will accept it for competition. So if I do build an engine for it again, it will have the crank triggered ignition for sure. I really think it's the way to go. Distributors are just... dinosaurs. Last edited by jeff denton; 09-14-2008 at 04:25 PM.. |
That is exactly what it acted like I dismantled my weber on the side of the road to find nothing out of place or wrong with it by then it cooled off enough that I ran it back home to change the coil as it was hot. Older original coil did the same exact thing but it didn't even make it 2 miles.
Hot Spark
For a little clarification, the Hot Spark units are far, far, far less reliable than the Pertronics units they copy. Most guys I know with VWs went through two or three until they got one that worked reliably, and then they still carry spare points and condensors just in case. Look around on any of the VW forums and you will find that almost no-one recommends them to anyone and that they usually don't work at all or have the same hot failure issue as Dennis Texas.
Wired correctly a real Pertronics or Comp-u-fire points eliminator module has never once let me down. I like the magnet assembly on the Comp-u-fire units better myself, but both have always worked flawlessly for me. |
I was just about to say what Stephen just said, these Pertronix "knock-offs", and that's what they are, are not up to being actual Pertronix. They hit Ebay far cheaper than Pertronix, and it shows. I have one Pertronix I have moved between 3 cars and all have run without a problem. If you don't or can't afford a Pertronix or Comp-u-fire, then by all means stay with the points, as they are stll the most reliable things going.
#16 (permalink) | |
'72 Opel GT (Sara)
Matt |
#17 (permalink) | ||
'72 Opel GT (Sara)
Thanks! Matt Last edited by newman27; 09-15-2008 at 01:09 PM.. Reason: Link to correct 1847V unit... |
#18 (permalink) | |
