Old 06-14-2008   #1 (permalink)
Unanswered: Flamethrower coil
AS I'm not the brightest on coils, is the Pertronix Flamethrower coil the type that requires the resistor wire or straight 12v wire from the fuse box?
Old 06-14-2008   #2 (permalink)
opelspyder's Avatar
Flame thrower
Depending on which Flamethrower coil you have determines if you require a ballast resistor/resistor wire. If it states on the package the ohm built in resistance of around 3.0, you don't need an external resistance. The coils that need the external resistor will say 1.5 or close. I like these 3 ohm coils better as you can run a straight 12v to them for use of Pertronix, and the wiring is quite neater. I hate the look of a ballast resistor
Keith
Last edited by kwilford; 06-15-2008 at 12:19 PM. Reason: corrected resistance spec
opelspyder is online now
Old 06-14-2008   #3 (permalink)
Keith;
I don't have the original box, is it marked on the coil itself somewhere?
Old 06-14-2008   #4 (permalink)
Gene,
If you have an ohm meter you can measure the resistance. If its a 1.5-1.6 ohm coil then use the factory resistor wire. If its a 3.0-3.1 ohm coil then you can run a new wire to the coil.
On my coil, it lists the ohm value on the Flamethrower label
Paul
Paul is offline
Old 06-14-2008   #5 (permalink)
Detritus Maximus
If I remember correctly, the Flamethrowers are available in both ohm ratings.
"No, it's not fiberglass."
opelbits is offline
Old 06-14-2008   #6 (permalink)
Gene
Which Opel are you working on? Your stable of Opels is a little large.
The reason I'm asking is that there are little tricks that might be applied for a faster coil saturation. ie higher rpms applications.
Old 06-14-2008   #7 (permalink)
Dan;
I'm trying to keep plugs in Lou's Wagon from fouling out so often. She drives (if you can put it that way) to Cumberland Mall and back everyday. With idling in traffic, she fouls out plugs. John was over and I was talking to him about it. He said to open up the plugs to about .040" and use a better coil than stock. Which is what she is running. She is running a Pertronix ignition, but, that's about all.
Old 06-14-2008   #8 (permalink)
opelspyder's Avatar
Coils
On a 3.0 Coil, I think you need to run a full 12V to it, not the resistor wire. Or at least I have for Pertronix. A 1.5 you run a ballast resistor or resistor wire to. Or am I backwards here. The ballast resistor acts as a resistor wire.
Keith
Last edited by kwilford; 06-15-2008 at 12:20 PM. Reason: corrected resistance spec
Old 06-15-2008   #9 (permalink)
Dan;
Oh the green Opel wagon.
What spark plugs? Autolight,champion..
I thought we were working on Tony's GT at first.
Current ramping
Look into the download section the stock 3.0 ohm coil will pull a little over 4 amps. Guess what happens when you lower the primary to 1.5 ohms.
Old 06-15-2008   #10 (permalink)
tomking's Avatar
Originally Posted by opelspyder View Post
On a 1.5 Coil, I think you need to run a full 12V to it, not the resistor wire. Or at least I have for pertronix. A 3.0 you run a ballast resistor or resistor wire to. Or am I backwards here. The balast resistor acts as a resistor wire.
Keith
I think you are backwards and suggest you correct your post so as to not confuse people who read it later.
TMK
tomking is offline
Old 06-15-2008   #11 (permalink)
If that doesn't cure the problem I would look at getting the next hotter heat range plug.
Old 06-15-2008   #12 (permalink)
Bill Hoffmann's Avatar
Bill Hoffmann
The 1.5 ohm coil requires an external resistance, while the 3.0 ohm does not. If you want high voltage while cranking using the stock wiring scheme, get the 1.5 ohm coil.
There is a discussion about it here: http://www.opelgt.com/forums/1b-igni...html#post96737
Bill Hoffmann is online now
Old 06-15-2008   #13 (permalink)
No....its not a Buick....
yellaopelgt's Avatar
Gene: If thats the coil I sent to you, its a 3.0 ohm.
BTW I have a bunch of those gaskets left over after my engine build ,so if you want them back,PM your address and I'll send em!
THANKS!
Joe
yellaopelgt is offline
Old 06-15-2008   #14 (permalink)
Yep, it's backwards so I will revise it for the other Keith
