Old 06-27-2008   #1 (permalink)
kaestnerautoelectric is on a distinguished road
Unanswered: need help finding ignition parts
Hello gentlemen, I am working on a ?1968 opel engine in an industrial app... I am trying to find ignition points, cap and rotor.... Or an upgrade to electronic ignition... I am a Pertronix Warehouse Distributor, However they only offer an upgrade for a Bosch Dist...
My distributor is stamped Delco Remy - Made in France 001 5486
The engine block number is 11-0091314
Any help would be appreciated,
Thanks,
Bob Bertnick, Service Manager
Kaestner Auto Electric
Waukesha Wi, 53186
262.547.9600
kaestnerautoelectric is offline
Old 06-27-2008   #2 (permalink)
Exclamation Just a GM 4-cyl Delco disti number . . .
Originally Posted by kaestnerautoelectric View Post
Hello gentlemen, I am working on a ?1968 opel engine in an industrial app... I am trying to find ignition points, cap and rotor.... Or an upgrade to electronic ignition... I am a Pertronix Warehouse Distributor, however they only offer an upgrade for a Bosch Dist...
Thanks,
Waukesha Wi, 53186
262.547.9600
. . . not exactly true, you just asked the wrong question . . . about an Opel 1.1 engine disti! They will only list Bosch distis for this engine, most likely, about 99% of them were.
Instead, try asking for a GM 4-cyl engine Delco disti and give them the Delco number only, don't even mention "Made in France" . . . it'll just confuse them!
Old 06-27-2008   #3 (permalink)
thanks for reply,
I have tried this... I am also a Delco TSS repair facility and I am having no luck thru my Delco resources ....
Old 06-27-2008   #4 (permalink)
Arrow Another try . . .
. . . OK, how about this then, '60s Chevy II 153CI 4-cyl engine disti then . . . look up points, rotor and cap and see if they fit Opel engine Delco disti. If so, you have your reference for Pertronix unit needed!
Remember, GM was run by "bean-counters" in those days and I can't imagine GM designing different distis for each of their 4-cyl engines worldwide, probably just different drive shaft lengths and gears depending on engine use . . . disti head and guts likely identical!
Oh, just a thought . . . have you verified that the Bosch points, rotor and cap listed won't work on that Delco disti?
Old 06-28-2008   #5 (permalink)
bello is on a distinguished road
Re Ignition parts for industrial Opel 1.1 motor-
Hi! Unless they have done something unusual for that application, why don't you just convert to a bosch distributor? Look at ebay Item #170232459036- though maybe someone in the forum may have an extra one for sale. The Bosch unit uses a more popular, easy to find point & condenser set! Ernie
bello is offline
