I had a problem once,the car would start and idle fine but if the engine was warm it didn't run fine, looked at everything but couldn't find what was wrong, because when the engine cooled down a bit it would run fine again until the engine warmed up again, we finaly found what was wrong, the bolts from the intake and exhaust manifold from the #4 cylinder were loose, maybe you have the same problem.
well i did check those intake bolts and they were good. i went ahead and checked compression just to make sure, that was fine. i changed the condenser and then went back to another slightly used cap i had. that appears to mostly work. at least now i'm firing all 4 most of the time. so i'm thinking - get a new distributor, a Pertronix unit and i'm not sure what coils would work. factory original or maybe an older Mallory or....? anybody recomend some options there?
Dallasmanta
Real Name: Ron
check to see if you have any distributor shaft play by removing the cap and moving the shaft where the rotor fits back and forth. If this checks out ok remove the points and check for burned tips. If ok spray them down with some brake cleaner to remove any oils. Then take the cap and check to see if you have any carbon build up on the brass terminals. If so use a small file or sharp knife to make sure any carbon is removed and you have a shinny brass surface that will allow the spark to be delivered to the spark plugs. Take the brake cleaner and spray the inside of the cap to remove any oils that may have been on the contacts and terminals. Spray the rotor cap also and keep from touching the brass end and the center where the carbon contact touches to complete the circuit. IF all this checks out and your symptoms come back when warm you have a failing plug wire. Replace it with a new set. Make sure the plug wires are not touching any metal that can ground the spark before it gets to the plug. If you are using the original resistor plug wires that had the brown end caps that plugged on to the spark plugs you may have a resistor that has failed and breaks down when hot.
Hope this helps Ron |
Clean the outside of the distributor where the condensor screws on to it. I had a problem where the condensor was not grounding because of pitting on the dizzy housing and my points would burn out badly UNTIL the new condesor actually welded itself to the dizzy housing due to the arc that developed by it trying to ground itself. Then it would run fine again until I tuned it up the next time and removed the condensor and broke that welded "ground". It would backfire and miss as the points burned due to no grounding of the condensor.
