Unanswered: Electronic Ignition Conversion on a DELCO distributor
This subject seems to have been covered fairly comprehensively with regards to the Bosch distributor system that came fitted to most Opel GT's... but I have a 1971 1.9 CIH Opel GT which has a Delco Distributor, not a Bosch. I would like to convert the ignition to an electronic ignition to get rid of the points and condenser etc. I have read and searched a lot, both in this site and others.. but does anyone know of a kit that I can use to do this? I purchased a Pertronix 1149C kit which I was told would work... but they have just agreed to refund me and cannot supply a kit that will work. The other option I have heard of is to find a Bosch electronic ignition kit from a number of other European cars, which is a direct replacement and is already electronic. Does anyone have any details of what cars this would have been fitted to, or ideally, a part number? I am based in the UK, so sourcing it once I know what I am looking for should be fairly straightforward. Many thanks Dan |
#2 (permalink) | |
However I *believe* it was a standard item for the Manta B 2.0 litre CIH, not sure of which years it fits. I seem to remember it also fit some models of Audi, VW, Alfa Romeo, BMW, etc. I wish I could help you with the part number, but I threw the parts box away some time ago. HTH, Bob
1971 GT
Is it an option to buy the bosch distributor assembly and start from there or is there further differences in the motor?
Many thanks dan |
Many thanks Dan |
Standard Opel
Yep - Opel used both Bosch and Delco distributors - they interchange but are different internally.
Also, the later Manta electronic distributors have often been available rebuilt on eBayuk for less than 20 quid. Just be sure you get the earlier version as late 1980's ones do not have advance weights and rely upon the ECU to adjust ignition advance. You will also need the amplifier module, the wiring loom and the correct hi-voltage coil to run the Manta electronic distributor. They drop straight in to the 1.9L motor ... and even have a fuel pump cam on them too.
I have no pics at this time, but the distributor number wouldn't help you at all either...it was a conversion kit, it fit inside my old Bosch distributor!
Why not just get a Bosch dizzy and drop it in with a Pertronix unit installed, seems like that would be much easier.
#9 (permalink) | |
The ideal situation for me would be to find a kit that works with my Delco, however, but that is looking increasingly unlikely. I am also trying to minimise the amount of work; It's becoming a very steep learning curve... this is my first car with a carb, for example. Although not that young anymore, I am young enough that i have never had to do points, rebuild a carb etc... I have previously been more at home with tailoring fuel maps for ECU's and the like. I am willing and still keen - I have already replaced the original carb with a twin choke weber 32/36 DGV and replaced and restored the fuel tank and all the associated fuel lines. I have also just ordered a new rad, thermostat and kenlo electric fan to sort out the cooling and many other odd jobs! It would just have been nice to find an electronic ignition kit for what I've got so as to minimise replacing bits and maximising driving it! Many thanks for the info though - it's all useful |
#10 (permalink) | |
The Pertronix Ignition Catalog in PDF format is downloadable, just click! It lists: Chevrolet 1962-74/GMC Truck 1964-66/Pontiac 1962-63 - All 4cyl with Delco distis - Ignitor 1144A . . . and not the 1149C (Triumph 4-cyl w. Delco) they told you in your first post!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 12-18-2008 at 09:32 PM. Reason: Add info . . . |
#11 (permalink) | |
1969 GT
Real Name: Tom
Wow guys, you got me nervous here. My first opel GT finally arrived today from the transport folks and I had already ordered the Pertronix kit for it - 1.9 engine and the number I was told for the 1.9 was 1847V, a 4 cylinder kit for Bosch systems. I found it on Ebay new from a Pertronix dealer for $65 who said it was for the Opel, and many other 4 cylinder inports, at least 30 or more listed but all Bosch systems, not Delco. The Delco system is new to me and as others have said maybe much harder to find. I don't recall seeing one Delco for 4 cylinder setups and my dealer did not even ask if I had a Delco [CIH - rarely used!] when looking my part number up. The Ebay seller I bought from does not have it listed anymore so maybe mine was the last one. At $65 I thought it to be a great price but there are other sellers with the 1847V so maybe you could look at there specs to verify the correct part number. I'm unable to go out there and install it for awhile. Here I was waiting patiently to get in my first Opel GT to arrive today and drive it for a few days before I start the restore process when I had to go out and snowthrow 3-4 inches of snow off the driveway Sunday morning. Falling badly on a patch of ice resulted in my surgery yesterday for several screws and a metal plate in my ankle. I'm not sure which hurts more, the injury or looking at my beauty in the driveway and unable to drive it for 8 weeks!! I guess if it were an automatic my left ankle could rest while I use my good foot for the gas/brake! ![]() Good luck in finding your setup. Last edited by tekenaar; 12-18-2008 at 09:42 PM. |
. . . apples vs. oranges! . . . Delco vs. Bosch CIH distributor triggering internals - different component (points/cam) mounting and dimensions! . . . ergo, different Ignitor trigger P/Ns required!
#13 (permalink) | |
#14 (permalink) | |
1969 GT
Hi Dan
For my 1.9 CIH I use the electronic ignition from a 1983 Opel Rekord 2.0S and it fits perfect. Distributor - Bosch 0237020042 Transistor unit - Bosch 1227022008 Coil - Bosch 1227020009
http://www.toontime.dk/gt.htm |
#17 (permalink) | |
Thanks for the suggestion. I have asked the seller to swap for this kit instead of issuing a refund. I will document, photograph and post instructions should it work! |
Hi Dan.
Any news? I´m having same problem as you... i have the delco distributor on my 1973 manta 1.9 cih and im looking for a pertronix or an electronic dizzy... the electronic dizzy is more easy to find... Did the pertronix fitted good the delco distributor? |
#19 (permalink) | |
No good news I'm afraid. I tried various electronic ignition kits, 3 different pertronix, a couple of lumenition and another one. Basically... none of them come close to fitting and all went back for refunds :-(. I am keeping an eye out for a Bosch dizzy to buy. I would be happy with either an electronic or one that needs converting! (Beggers can't be choosers!), but I have mastered points now, so I am in no rush at all! Dan |
#20 (permalink) |
Thakns Dan.
I think i´m also going to get a bosch distributor, but i think i will go directly to the electronic one. ![]() Thanks for your reply. I have on my manta a 1900 cih 2 webers dcoes and i already advance the ignition but i still notice that the fuel isn´t all "burned" in the explosion, because my spark plugs are too black... At thos point i´m trying to find the best ºs of advance... rgds, Pedro |
#22 (permalink) | |
Then work on the fuel mixture for the side drafts. After you get the A/F ratios where you want them.. then start adding back timing until the torque starts to drop off.From there on in its all tweeking this and that to get the optimum timing. |
