Real Name: Henry Padlo
Answered: Timing almost 50 degrees off ???
Most Helpful Answer - Posted by badmaxdog
| O.K. The mark on the flywheel that I was looking at was the wrong one. It was actually a machined hole in the wheel. I found the correct mark after changing my inductive clamp to No. 4 plug wire. I think the light was strobing too much on No. 1 for me to see the correct mark and thought that the hole was the steel ball. Dummy me. I should be still able to time on No.4 on a four cylinder since TDC should be same as No. 1. Correct?? I should probably buy a better light. I read elsewhere on another forum that the stock low compression engine may run a little better with the timing advanced. Anyone else had any experience/advise on this? If so how many degrees should I advance it? |
Uber Genius
I have an idea. It's quite possible, though not probable, that the timing chain was put on wrong. If the timing chain was correct then the engine should NOT run at 50 degrees off.
Putting the distributor in on the incorrect tooth wouldn't do it because you would just spin the distributor to get it to fire on the ball. If the timing chain was installed with the hole lined up straight up (or down) then it very well could be off by... you guessed it...50 degrees.
i would go back to basics
set the ball to pointer(make sure its ball and not some odd mark on flywheel ) and then set timing up by having the dizzy loose with the cap off line the dizzy #1 mark ( line on edge of dizzy ) to centre of rotor arm , then replace cap put a spare spark plug in #1 ignition lead and with plug grounded , turn the dizzy a little counter clock wise ( been 26 years since i timed a CIH so it may be the other way ) and back again slowly till you get a spark at plug , tighten dizzy and replace plug lead , add dab of tippex to crank pulley and case to show marks for future use then start engine hth
One and four are companion cylinders.
If the timing light wont trigger off number one most likey open plug wire on .... You think that timing is important. Nope think more about the burn speed of the fuel your using. Last edited by wrench459; 05-29-2009 at 12:12 AM. |
