I may be off by a bit but I think voltage is usually knocked down around 3 or 4 volts to ~9 volts by the resistor wire after the initial 12 volts to start.
On the primary side 3 ohms.. the secondary side depends on the number of turns in the coil for the inductive kick woooo.
If you want to dig deeper into this check out the download section. opphs I misread this post soorrry..check into the coil ramp time.Thats whats you after correct? One coil four cylinders to fire :-( Last edited by wrench459; 06-22-2009 at 10:38 PM. |
#4 (permalink) | ||
Keith Wilford working on my '71 GT and '75 SportWagon Last edited by tekenaar; 06-24-2009 at 01:17 PM. Reason: correct resistances |
Opelitis since 1984
Real Name: Charles Goin
The same as a 75 Dodge Dart or most others.
ACDelco Resistor Part No. C1102 its about $5-10 Its a pretty universal part if your changing the resistor wire out to a standard wire and still have points.
. . . did this earlier this year for my Dutch friends . . .
I'm coming up with 1.4 ohms on the primary. Don't have a clue where the 3 ohm's came from other than a senior moment
![]() As far as the current ramp of a stock Opel.Attachment 22336 Last edited by wrench459; 09-01-2009 at 11:20 PM. |
