He recommended, and I bought, part number 60130, a 3.0 ohm Flame Thrower HV, apparently designed for 4 and 6 cyl engines with points, optical triggers or Ignitor ignitions... lotta juice at 60KV, but he assured me that would be fine with an Ignitor in a GT.... I put in the Flamethrower and the car seems to run fine forthe few runs around the block... and now I am about to swap out the points for the Pertronix Ignitor... and read here, all the worries about the resistor wire, hookups, and special wiring to avoid frying the unit or causing it to shut down after a few miles.... So, my question - do I need a resistor? New wiring? Is my flamethrower of sufficiently high resistance to not need an added resistor? If I need a new pos and neg, where do I tap off for the correct running of the Ignitor? I would not doubt this has already been asked somewhere, but I have not found it yet... I did find some talk about rewiring - which to me did not sound like the simple drop-in pertronix guy was telling me, using the Flamethrower... LOLAny thoughts GREATLY appreciated! Thanks, Paul Flagstaff AZ 73 Yellow GT Last edited by tekenaar; 10-12-2009 at 11:30 AM. Reason: PeRtronix |
Look at the diagram in Otto's (tekenaar) post 35 of this thread. I don't know if this answers your question, but, it couldn't hurt.
"Yes, I do have a rifle rack in my Sportwagon" Last edited by tekenaar; 10-13-2009 at 10:31 AM. |
'72 Opel GT (Sara)
As I recall, some coils have an internal resistor and some don't. I would check into that as well with respect to the flamethrower unit you purchased. This piece of the puzzle may have also been covered in the thread that Gene linked...
Keith Wilford working on my '71 GT and '75 SportWagon Last edited by kwilford; 10-12-2009 at 01:14 PM. |
Did the same as you with the flame thrower & pertronix & had the same problems.Feel your frustration.Even withe the mechanic talking to the pertronix & frame thrower guys he got it wrong . A different mechanic finally got it right.Had to ditch the flame thrower & put in a resister.Been perect since.To some people this is easy stuff but personally wiring is evil!
Dale, what Flamethrower coil did you have? There are both low resistance (0.45 and 1.5 ohm) and 3 ohm versions (no resistor and internal resistor respectively) so if you have the "correct" 3 ohm version, no need for a resistor wire. And FWIW, if you want to use a non-resistor coil (as in an Opel OEM coil or similar aftermarket coil) you ONLY power the coil with the resistor wire; the Pertronix itself MUST be powered with a non-resistored supply. HTH
Keith Wilford working on my '71 GT and '75 SportWagon Last edited by kwilford; 10-13-2009 at 01:46 AM. |
Thanks again - Paul Flagstaff, AZ 73 Yellow GT
#8 (permalink) | |
so, this is the correct setup, and I pick up 12 V off the starter, then trace back the clear resistor wire and snip the bugger off wherever that traces back to (where?)...? and then hook up as thus? So: >>>>CLIP>>>>> Ok, I just want to check BEFORE I turn the key. I have a Flamethrower 3 ohm internal resistance coil and an Ignitor I. Is this okay so far? I connect the BLACK wire from the Ignitor to the negative (-) terminal on the coil. I connect the RED wire from the Ignitor to the positive (+) terminal on the coil. I connect the GREEN wire from the tachometer to the negative (-) terminal on the coil. I connect the BLACK wire from the starter to the positive (+) terminal on the coil. Finally, because I have an internally resisted coil, I replace the clear resistor wire with a normal wire and connect that to the positive (+) terminal on the coil. Any objections? TIA, Jay Yes . . . BEFORE I turn the key. Yes . . . BLACK wire from the Ignitor. Yes . . . RED wire from the Ignitor. Yes . . . GREEN wire. Yes . . . BLACK wire from the starter. Yes . . . replace the clear resistor wire with a normal wire. >>>UNCLIP>>>> Seems like the green tach wire is not changing much fron stock, right? And the black wire from the starter to the (+) on the coil sounds counter-intuitive, since black is usually (-), but oh well... Man I wish I had a photo of the right wires going where LOLThanks all! Paul Flagstaff AZ 73 opel GT
Mike's Opel Shop
I think if you measure the ohm's of your coil and it's less than 3 or zero ohms than you connect the clear wire to the pos. side of coil. The 3 ohm coils needs resistor before + side of coil. The wire that comes from the starter to the + side of coil only gives 12 volts to coil when your cranking the engine (starter) as an added boost to the coil.
Flame Thrower coils come in two types. I am using a Mallory Coil in my GT also MSD makes one too. If wrong coil is used the Pertronix will just burn up in minutes. One more thing that people always forget. Never leave your key switch to on postion, when engine not running. If your parked and turn key on to listen to your radio, this will overheat the coil and burn out the pertronix and you will not be able to start the engine. Pertronix will burn up ![]() I have an extra pertronix that I take with me, but I never had to use it.
MIKE --------------------------------------------------- 1972 Opel GT,Citris Yellow 2.0L, Weber 38DGES 1969 Opel GT in Paint Shop 1973 MGB, Red, Weber 38DGES I have pride in my rides
#10 (permalink) | |
Opel Intern
(The purple wire is what replaces the clear resistor wire) |
Mike's Opel Shop
Check out this too, Otto's Post #14
#13 (permalink) | |
Mike's Opel Shop
Pertronix Hook up
FWIW, If it were me. I would just get the right coil. Use the clear resistor wire if it's not burn out (open). Then you don't have to run a new wire. It's makes everything look neat and simple. Just my thoughts.
What ever you decide to do, Good Luck Pertronix's is better than adjusting Dist. points. Off topic: Have you installed a 12 volt starter relay to protect your igntion switch from overload and burn out ?? It's a Good idea
#15 (permalink) | |
.And I did buy a relay - it is on my list of fun to do on the ole ride! thanks again! Paul Flagstaff AZ 73 Opel GT
#16 (permalink) | ||
![]() That said, another solution is to install that relay so desirable to protect the GT's ignition switch contacts, take the power supply from the starter post (using a fuse to protect the wiring) and use the stock resistor wire to ONLY switch the relay. If you don't understand what I am suggesting, don't do it and read on. No, this is incorrect. The Flamethrower 3 ohm coil IS an internal resistance coil. If you use the Opel factory coil (or some other non-resistored coil) THEN you still use the resistor wire to energize the coil, BUT NOT the Pertronix itself, as it MUST be powered by the full 12 volts. And not to make too fine a point of it, FULL voltage of a automobile "12 volt" system is actually between 13.8 and 14.4 volts, in case someone takes their volt meter to the coil +'ve post
#17 (permalink) | |
Sorry, I am still a newbie! .. and I imagine I can find a way through the firewall to the fuseblock, but do folks here have a typical, "easiest" route through the firewall? thanks - I see in the thread above, and with others, that a 2nd new wire up from the starter is suggested by some - I presume to offer extra amps and prevent voltage "sag"... And this second wire does not seem essential, but at least a "good idea", eh? You are right, in all it does not seem hard at all - just antsy about frying stuff without being clear on what goes where - thanks again! Paul Flagstaff AZ 73 Yellow GT
#18 (permalink) | ||
