Ultimate Opel Spark Plug - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 84
Like Tree24Likes
Thread: Ultimate Opel Spark Plug
  1. #61
    Mar 2012
    Scottsdale, Az
    1,645
    Yes, with NGK, the number is in reference to heat range.
    Lower is colder, I believe. (Per the NGK website:
    The image below is a representation of the difference between a hot and cold heat range. NGK spark plugs’ heat range goes from 2 (hottest) to 11 (coldest).)
    If you are fouling then you need a hotter plug. If you are dieseling then a colder one.
    With the 2.4, you need to watch the Temps. Colder plugs will be better than hotter ones.
    https://www.ngksparkplugs.com/about-ngk/spark-plug-101/understanding-heat-range
    PS - 0.7 mm is approximately .028 inches
  3. #62
    Nov 2007
    Cöllingswööd, NJ
    9,568
    Gördö
    6
    Okay, if that's true, then I'm running the next cooler than stock recommended temperature plug, which that, and maybe another step cooler, is what MSD recommends. So, it appears I'm on the right track as far as plug choice.
    As far as driving and checking the spark plug color, as I've stated previously(and possibly heard from RallyBob, I think), multi-spark systems like an MSD tend to be "self cleaning". The spark plugs always look the same perfect light brown color. Even the Red Baron's 90-100-50-90(something like that), beat-but-ferocious(crazy cam....yee-ha!), engine couldn't discolor the plugs.
    Is Norbert's plug list the same as what is recommended for factory 2.0's?
    Do each spec the same type of plugs?(2.0-2.2-2.4 the same?)
    Soooooo, since I seem to be, based on 69whiteGT's research(?)(not to discount FO81's "I believe" ), in a safe range with my plug choice, shall we say that it's the concensus that I gotta drop that plug gap down to somewhere between .025-.030 ??? And that .045 is way out of the ballpark?
  4. #63
    Nov 2007
    Cöllingswööd, NJ
    9,568
    Gördö
    6
    Can I also presume that too large a gap can overheat the plug, possibly causing preignition, and cause missing if the spark can't jump the gap?
  6. #64
    Mar 2012
    Scottsdale, Az
    1,645
    Quote Originally Posted by GeorgeOpel View Post
    Whats the best plug to use in a 73 Lotus Europa 1.6L twin cam engine. Ford cosworth block/ lotus head?
    That engine works best if you stick the pointy part of your head into the hole!
    JMHO -- Doug
    The Scifi Guy likes this.
  7. #65
    Jul 2005
    Milner, GA.
    11,216
    Dan
    12
    Well I think that your confusing true multi-spark with the MSD capacitance discharge.
    True multi will fire the spark KV aka firing voltage several times at low rpms.
    The MSD unit is like a buzz saw... firing only during the burn time.
  8. #66
    Opeler 69whitegt's Avatar
    Jan 2006
    Cincinnati, Ohio
    656
    David
    .45 does seem a little high, I would gap it no more then .40, probably more around .35 is where you need to be. Go put some miles on that long strokin' 2.4 beast!
    ____________________________
    . 1972 GT " Ms. Cali "
    . 1.9 High Comp.
    . Sprint Manifold
    . 32/36 Weber
    . Isky OR-66 camshaft
  9. #67
    Mar 2012
    Scottsdale, Az
    1,645
    It's been a really long time, but MSD used to also recommend more gap for their super hot spark? I would find it hard to believe that the new gap would be 60% greater however! The .035" gap would be 25% higher than the .028 recommended by Opel.
    Doug
  10. #68
    Jul 2005
    Milner, GA.
    11,216
    Dan
    12
    STOP THINKING
    With to large of-a-gap the combustion chamber temps will run cooler as also the sparkler.
  11. #69
    Jul 2005
    Milner, GA.
    11,216
    Dan
    12
    Setting back in my arm chair.
    There are three areas to think about.
    1: Firing line voltage
    This is the amount of voltage to cross the gap.
    Measured as thousands of volts aka KV
    Second is burn time.
    This is measured in ms.
    A kool clip is around two ms
    The third is burn duration.
    Both burn and the above should be square.
    If confused ..jump back and reread this thread.
  12. #70
    Nov 2007
    Cöllingswööd, NJ
    9,568
    Gördö
    6
    STOP THINKING
    Well, gosh dang it, which one should I do!
  13. #71
    Dec 2009
    Germany/Bremen
    2,676
    Norbert
    Btw.With a colder spark plug and greater gap the self cleaning affect will be died
  14. #72
    Nov 2007
    Cöllingswööd, NJ
    9,568
    Gördö
    6
    I reduced the plug gap to around .030". The car started easier and the miss while warming up went away. The plugs were black, which the previous plugs the car had in it for 150 miles and which were in the Baron for 1500+(gapped to .030-.035), never were. They were previously always light brown when used in both cars' engines. So I guess that Norb' was right and the self-cleaning effect did not happen when the gap was too large. I'll put another 100 or so miles on them and see how they look.
  15. #73
    Jul 2005
    Milner, GA.
    11,216
    Dan
    12
    Fired my GT up the other day.
    It's been setting in storage due to some health problems,
    The sucker ran like %$@^&$.
    Removed all the sparklers found one that looked a bit odd.
    Waveform to follow...I forgot the CF card tonight
    guyopel likes this.
  16. #74
    Nov 2007
    Cöllingswööd, NJ
    9,568
    Gördö
    6
    I'm currently using the NGK BPR7HS spark plugs that I used to use in my 2.0.......in my 2.4.
    In discussion with Charlie about fuel economy and such, he suggested using a "cooler" temperature plug, like a 6HS.
    What the heck does all this hotter/cooler stuff mean in regards to spark plugs and how can hotter/cooler affect gas mileage? Someone please give a long dissertation on the subject.
    Next question: What is the factory recommended spark plug for a Frontera/Omega 2.4 engine?
    Since I'm running a side draft carb, should I adjust the temperature rating of the spark plug to take that into account?
    No charts Dan! Please confine yourself to endearing, folksy, country-speak! "Well, Gordy, it's just like when a 'coon gits inta the hen house. When the hens're cold the eggs is old and when the rooster's a crowin' the hay needs a mowin'."
    Wh.....wh.....whaaat?
  17. #75
    Jan 2006
    Cincinnati, Ohio
    656
    David
    No charts Dan! Please confine yourself to endearing, folksy, country-speak! "Well, Gordy, it's just like when a 'coon gits inta the hen house. When the hens're cold the eggs is hot and when the rooster's a crowin' the hay needs a mowin'."
    Gordo, If you want a "colder" plug you would go to a BPR8HS. The 6HS would be a "hotter" plug then what your running. What do you plugs look like in your engine? If they are "tan" I would leave them alone... Post some pictures of the #2 spark plug, it typically runs the hottest. It's usually a good indicator of how clean your engine is running.
    RallyBob likes this.
    . 1.9 High Comp.
    . Sprint Manifold
    . 32/36 Weber
  18. #76
    Jul 2005
    Milner, GA.
    11,216
    Dan
    12
    Gordo the cow say's eat mor chikin.
    The ground strap electrode should turn color 2/3ths of the way(proper heat range) for a street sweeper.
  19. #77
    Spofford, NH
    12,425
    Bob Legere
    Quote Originally Posted by 69whitegt View Post
    ^^^^^This^^^^!!
    Gordo, NGK plugs are rated 'backwards' compared to say, a Bosch plug. Lower numbers are hotter, higher numbers are cooler.
  20. #78
    2000 Post Club My location m610's Avatar
    May 2010
    Davis, CA USA
    2,991
    Mike Meier
    My understanding is hotter plugs are designed to run hotter, and cooler plugs cooler, and in both cases it's more about their ability to tolerate heat, to conduct it away from the electrode. I don't think it has anything to do with the spark itself.
  21. #79
    Jan 2016
    Albuquerque, NM
    456
    Joseph Bauer
    Quote Originally Posted by baz View Post
    how about making a collar 1/4" long that threads on to plug, could be tapered to match plug if needed or add compression washer, add a little exhaust compound and have the plug tip in the right spot with no threads showing ?
    I'm gonna bump the above idea. No one talked about it.
    As for the temperature range of a spark plug, it has to do with the ceramic insulator. The hotter a plug, the less ceramic insulator there is to serve as a heat barrier, exposing the electrode to heat quicker. It has nothing to do with the ability of the spark plug's spark itself, and more to do with melting the plugs / pre-ignition or fouling. Engines that are used in high performance applications run colder plugs because racers don't want to destroy their engine when the plugs get so hot, that they pre-ignite the fuel. If two plugs of identical design except their temperature rating are used, the spark will be the same. The temperature of the plug would only impact fuel economy if the temperature of the plug wasn't correct for the application, causing the plug to foul from carbon build up (bad spark, misfire) or overheat (pre-ignite). I believe I communicated all this correctly, it's been a long day.
    m610 likes this.
    ~Joe
    "Autoholism is an incurable addiction medicated daily with car porn." ~Me
    "the sickest of the sick — a car guy who is collecting parts for the restoration of a car he doesn’t even own yet." ~Anonymous
  22. #80
    Jan 2016
    Albuquerque, NM
    456
    Joseph Bauer
    Something to think about. I'm sure one day in the not too distant future, there will be laser plugs for classic cars.
    https://www.newscientist.com/article...e-efficiently/
    ~Joe
    1. Increasing Spark Plug Gap?
      By ronskydivepops in forum 1B - Ignition System
      Last Post: 07-24-2016, 06:58 PM
    2. 2.2 spark plug options
      By jayhawkjesse33 in forum 6E - Tune Up
      Last Post: 09-09-2011, 09:57 PM
    3. Which Spark Plug for a EFI 75 Manta?
      By Gordy in forum 6E - Tune Up
      Last Post: 09-09-2010, 12:57 PM
    4. spark plug wires
      By rbuhler in forum 1B - Ignition System
      Last Post: 11-25-2009, 10:13 AM
