12 Steps for Electronic Opel Ignition
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: 12 Steps for Electronic Opel Ignition
    Plano, TX 75074
    5,297
    Otto
    Lightbulb12 Steps for Electronic Opel Ignition
    Simplest installation of electronically triggered ignition in a GT is to purchase and use Pertronix/Hot-Spark trigger and stock coil. Here's how:
    1. Remove cap, rotor, points and condenser with green wire from distributor and disconnect green "condenser/points" wire from coil. Leave everything else connected as-is.
    2. Install Pertronix/Hot-Spark trigger amp module where points were, do not tighten mounting screws yet.
    3. Run red and black module wires out "points wire" hole in side of distributor and install grommet in "points wire" hole, leaving a bit of slack on both wires inside of distributor.
    4. Push black plastic magnet unit onto distributor shaft and seat over points cam.
    5. Adjust trigger amp module to magnet unit clearance using clear plastic gauge that is provided and tighten trigger module screws.
    6. Replace rotor and cap . . . you're now done with the distributor.
    7. Connect black Pertronix/Hot-Spark wire to coil contact from which you removed the green points wire.
    8. Cut an 18" length of 16/18 gauge red wire, strip both ends ~1/4" and crimp on a 1/4" female spade connector on one end.
    9. Locate clear (resistance) wire at front of fuse #3 (from passenger side) of the fuse box and attach red wire terminal on an extra lug there. This is your switched 12V (turns on with ignition key) source for powering Pertronix/Hot-Spark.
    10. Run the other end of the red wire through the firewall at the windshield washer foot pump hose grommet.
    11. Crimp 1/4" male spade connector to red wire now underhood and connect to matching Pertronix/Hot-Spark red wire female spade terminal.
    12. To paraphrase our own SouthWest Airlines: "You're now free to move about the country!"
    'NO,......O P E L..G T!' My location Motor Mouth's Avatar
    Jul 2003
    Lincoln, UK
    585
    An 'idiots guide' fantastic.
    How much does the Petronix unit cost?
    Mark
    '69 GT - ex Dealer Opel Team
    Plano, TX 75074
    5,297
    Otto
    Thumbs upPertronix
    Quote Originally Posted by Motor Mouth
    How much does the Pertronix unit cost?
    Depends on where and when you buy it . . . Bugstuff usually has it on sale for about $45 during Carlisle and at Thanksgiving. That's generally thought to be about the least $. Have purchased all of mine from them except for the very first one back in '78 when Pertronix was still Perlux and speaks for itself as far as reliability is concerned. Still own that GT which I converted to FI back then . . . one of the very first FI GTs anywhere!
    Jun 2004
    Albertville,Al
    7
    QuestionStep Nine
    I need more help with step nine, my first time with this and I'm not sure how to find this resistance wire or lug. Thanks for any help
  7. #5
    Plano, TX 75074
    5,297
    Otto
    ArrowPertronix fuse box power connection
    Quote Originally Posted by d slaton
    Fuse box inside GT, front of 3rd fuse from passenger side is where clear, resistance wire for coil + is connected. This location has a couple of spare male spade lugs to which you would connect the female spade lug of the red wire you just fabricated per instructions.
  8. #6
    Senior Contributor My location asdasc's Avatar
    Oct 2005
    Mt. Clemens, Michigan
    876
    Coil Resistance question
    I have a 70 GT (my 3rd one) and the PO added a Pertronics Coil and Elec Ignition. I was told that with the new coil, I still need the resistance wire. Supposedly Pertronics makes two different coils and you can't tell them apart. If it 3 ohms, you need the resistance wire. If it is 1.5 ohms, you need to replace it like the instructions here say. You can easily measure the resistance with a decent ohm meter. Just be sure to disconnect everything from the coil before measuring.
  9. #7
    Plano, TX 75074
    5,297
    Otto
    Quote Originally Posted by asdasc
    If coil is ~3 ohms (has internal resistor), you DON'T need external resistance. If coil is ~1.5 ohms (no internal resistor), you need external resistance and separate wire with full 12V to Pertronics!
  10. #8
    Senior Member My location EJprovost's Avatar
    Oct 2004
    Utah
    509
    Thanks!
    Just printed this out, Thanks for laying this out so easy to understand.
    "Enjoy The Ride!"
    1969 GT, 1973 GT "Quazar"
    1995 Camaro Z28
    New Birthday presents for daughters:
    1970 GT, 1971 GT
  11. #9
    Oct 2005
    876
    Thanks Tekenaar! Now I have to go back and double check what I did. What you say makes sense, and it seems to be running ok. By the way, after reading your other posts, I am going to re-jet my DGAV!
    Thanks for keeping me straight!
  12. #10
    Oct 2005
    876
    Hello, Does anyone know what the 'gap' is in step 5? The module in my GT was installed by the PO and I am not sure if it is right. I am having some minor ignition issues, and am trying to figure out what is causing it. I DO know that I need to run 12v to the red wire on the pertronix. The PO had it run to the resistor wire.
    Thanks,
  13. #11
    Oct 2002
    Mahopac, NY
    4,036
    Per the Pertronix instruction sheet the proper gap is .030"
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
  14. #12
    Senior Contributor Willy_g77's Avatar
    Jul 2003
    Casey, IL USA
    540
    I just ordered the pertronix 1847v unit and flamethrower coil. my question is that, do i have to run a resistor wire when using the flamethrower coil? thanks in advance, I'm sure I'll have more questions when it gets here.
    {)BILLY(} & The 71' GT
    73 manta luxus
    real cars don't power the front wheels...... they lift 'em
  15. #13
    Opeler My location
    Oct 2003
    62
    Does Pertronixs gap affect dwell?
    Sorry if this sounds like an obviously dumb question, but will the gap between the Pertronixs bits affect the dwell? I set the gap using the included spacer, and am getting a solid dwell of 55, which is more than stock. I haven't experimented yet, and figured the answer might be beneficial to many. I figured it was all set within the device and not adjustable, with the spacing nothing more than the point at which the unit activates, so I haven't bothered checking.
  16. #14
    Non Civilian My location opelwasp's Avatar
    Mar 2003
    Between Chico and Sac, CA
    2,029
    Not a dumb question. A Pertronix uses a "Hall-effect" magnetic proximity sensor and magnets to trigger the coil. Points, essentially a switch, "trigger" the coil when opened. Dwell is the measurement of how much time it takes the points to go from touching to it's furthest point. Like I said the Pertronix is magnetic and they never touch. So dwell is not so much a factor. When you get a Pertronix it does come with a .30" spacer to set the proper distance for the magnetic field. You do usually need to adjust the timing though, it will be close but not quite right.
    1971 GT (Opelwasp)
    1974 Manta A (Polizei)
    1973 Manta A (junker)
    1973 GT (junker)
    2001 Dodge Durango SLT 4x4
    2004 Dodge Neon SXT
    2002 Suzuki SV650S
  17. #15
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    Question
    Riddle me this.
    I have a Bosch coil that measures just a bit over 1 Ohm resistance from +terminal to -terminal will all of the wires hooked up (before installing the Pertronix.
    When installing a new fuse block and connecting the wires I noticed that the clear resistor wire had melted insulation from a short. That was awhile ago so I forget if I or a previous owner connected a wire from the fuse block to the +terminal of the coil to replace it.
    What resistance, length, gauge should the resistance wire be if I want to re-use the stock (1+ Ohm) coil with a new Pertronics unit?
    What gauge wire should be used to go from fuse block to Pertronics and coil for the new setup if still using a resistance wire and stock coil?
    Is it better to take out the resistor wire, replace with new wiring (at the same point on the fuse block) and get a new , points style, 3 Ohm internal resistance coil?
    What's your favorite color?
    Thanks.
  18. #16
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    Does anybody have any opinions on the last question I tacked on to this thread? I want to install a Pertronix ignition tomorrow and was going to use these responses to decide which way to go, new coil? Stay with a stock type coil? I found one that has 5 Ohms resistance. Keep a "resistor cable" (as the schematic calls it)?, etc.
    Thanks.
  19. #17
    Member My location Gordy's Avatar
    Loves Park, IL (Rockford area)
    1,697
    I have a Pirrahna electronic ignition in my 1970 GT that I bought new in 1979 from Auto Sport in Calf.. It has been trouble free for almost 30 years. In all my other Opels I have the Pertronix systems and also have had zero problems. One difference is the Pirrahna has a 3" x 4" by1/2" "box" which mounts and the wires lead into it.
  20. #18
    Plano, TX 75074
    5,297
    Otto
    AngryCoil discourse . . . "I" vs. "E" resistors . . . SEARCH!
    Quote Originally Posted by BDD View Post
    Thanks.
    Read this entire thread about coil/resistor recommendations . . . found it by using SEARCH - "Bosch coil" . . .
  21. #19
    Plano, TX 75074
    5,297
    Otto
    ArrowExternal resistor thread
    Look here for info on external resistors to use with non-resistor coil like stock "tan-top" Bosch . . .
    . . . and another on Bosch coils used on Opels!
  22. #20
    Member Twintrouble's Avatar
    Jun 2010
    Seattle Wa
    250
    Duncan
    research
    Looking at the fire fox electric ignition. What does this take the place of(volt reg, coil)?
    1. go electronic ignition or something else
      By tevo in forum 1B - Ignition System
      Last Post: 11-10-2008, 06:49 AM
    2. Electronic Ignition
      By Kappy in forum 1B - Ignition System
      Last Post: 03-12-2008, 01:06 PM
    3. Electronic Ignition Map
      By greenbarron in forum 1B - Ignition System
      Last Post: 03-20-2006, 08:30 PM
    4. Electronic Ignition
      By shaggy in forum 1B - Ignition System
      Last Post: 02-23-2005, 10:22 AM
    5. electronic ignition
      By Wolf Spyder in forum 1B - Ignition System
      Last Post: 01-18-2005, 11:31 AM
