Opel GT ignition switch
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By jlthunder
  • 1 Post By wrench459
Thread: Opel GT ignition switch
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    I think my ignition switch may have just failed. I turn the key and the starter engages but there is no ignition and the instrument lights and gauges don't work or light up. What are the options?
    Thanks.
    Jul 2003
    San Diego, CA
    2,280
    Ignition switch RUN is white connector (12 BLK No. 2) that connects to switched fuses F5, F6, F7.
    Carefully disconnect and reconnect fuse box white connector. Check voltage to these fuses.
    Ensure the 12GA black wire (from ignition switch) is connected to fuse box (S/B at fuse F7).
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    white plug replacement 72 GT
    I need to get another white plug that is located on the inside of the fusebox. The plug that attaches from the outside was melted at the red main power wire so I found a replacement plug from another old wiring harness that I have. The problem is this one doesn't seem to mate with the one in the fusebox and I don't have a spare part for that. The original plug that connects from the steering column side appears to be a bit smaller and has rounded sides. The replacement I found has square sides. It might b efrom a '73.
    Are there new plugs I could get that would fit in the fusebox or does someone have an original plug they could sell me?
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    Beuller......Beuller.......Beuller?
  7. #5
    1000 Post Club My location jlthunder's Avatar
    May 2003
    Salfordville, PA
    3,982
    PM me your address. I will check my inventory. If I have one, I will send you the male and female so you know they match up
    norbertone.gt371 likes this.
    1973 GT, Parted out, R.I.P.
    1968 Kadett, Owner since 2006, Sold, 28 June 2008
  8. #6
    Nov 2007
    Cöllingswööd, NJ
    9,823
    Gördö
    6
    Well, if your ignition switch has failed, getting a new connector plug ain't gonna help. Since you "may" need a new switch, why not call up OGTS and buy one and ask about the connector issue? Maybe it's included with the new switch.
    Those almost 50 year old fuse box connectors are getting mighty aged and many times Opelers have electrical problems due to the connectors simply not engaging the electrical terminals very well. Often the terminals in the connectors on the fuse box get pushed in, disconnecting them from the plastic connector. I would suggest taking a good hard look at the prongs to make sure they are all even and you don't have one pushed through. Clean them up with contact cleaner. Use needle nose pliers to pull them back out if they're pushed in too far(disconnect the battery before doing so). Make sure that none of the female prongs have been bent or crushed closed. If you're adept at using a voltmeter you could plug the connectors together and check for continuity through the connector at each wire(not easy to do on an Opel fuse box). If all have continuity through the connector, then the connector ain't your problem.
    Good luck!
  9. #7
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Upgrade the box with new molex pigtails?
    guyopel likes this.
  10. #8
    Opel Intern Swiftus's Avatar
    Aug 2008
    Corvallis, Oregon
    1,205
    Jay Swift
    After having working with a number of different connectors, my vote for anything that has a chance of getting wet are Deutch DT or DTM connectors.
  11. #9
    Aug 2006
    Goderich, Ontario Canada
    2,707
    P.J.
    Opel GT has notoriously unreliable ignition switch. Many of us have added relay to protect START circuit and this is all good. However, let us not forget that all current is flowing through the ignition switch in RUN position. We added, electrical fuel pumps, electrical fans, additional lights, etc. and secured that everything works by upgrading alternator. Doing that, we caused even more current going through the ignition switch.
    I have also protected RUN circuit by adding relay, very similar to what we do for START circuit. You will likely need 40A relay although I am using 60A relay due to electrical power steering. There is very little current going through the ignition switch/white plug which should now last much longer.
  12. #10
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    I have replaced the switch and repainted the turn signal lever and the metal enclosure that goes around the wiring and key cylinder, etc. I just need this to connect things back up.
  13. #11
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    Opel GT has notoriously unreliable ignition switch. Many of us have added relay to protect START circuit and this is all good. However, let us not forget that all current is flowing through the ignition switch in RUN position. .
    I do plan to protect my new ignition switch and wiring with a relay but for now just need the white plugs the wires go into. Either original parts or replacement parts that hopefully work with the original fuse box.
    What do you use for this if you can't find an original matching pair of Opel connectors? The replacement part I found in my parts stash will not fit the one that's in the fuse box.
    1. Ignition Switch...
      By Ooooner in forum 1B - Ignition System
      Last Post: 03-23-2015, 09:32 PM
    2. Ignition switch
      By opelgtboy70 in forum 1A - Starting and Charging System
      Last Post: 05-04-2008, 01:09 PM
    3. opel ignition switch saver
      By ddoyle in forum 1A - Starting and Charging System
      Last Post: 12-14-2003, 03:02 PM
    4. opel ignition switch saver
      By ddoyle in forum General FAQ's
      Last Post: 05-13-2003, 10:19 AM
