Testing the S-ECU Lite
Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By blancojp (R.I.P.)
  • 2 Post By blancojp (R.I.P.)
Thread: Testing the S-ECU Lite
    Oct 2005
    Acworth, GA
    3,088
    juan P. Blanco PH.D.
    First of all, I want to thank Charles for all his hard work, he was one of the guys that made this possible.
    In order to test some of the new features of the Manager software, I created a portable crank trigger system. A little bit of machining by Pat did the trick. It is nothing more than a scaled down (2.5") Opel trigger wheel and a 1850 Rpm electric motor. I can spin the motor and see the crank sensor signals with the S-ECU, which can be used to check out the Manager software and fine tune a running application without an actual engine hooked up to it.
    Last edited by blancojp (R.I.P.); 07-19-2016 at 07:57 PM. Reason: ran out of batteries
    www.edcatl.com
    Home of the S-ECU
    Oct 2005
    Acworth, GA
    3,088
    The preliminary S-ECU Lite is here
    With all of the data we gathered using the SS4 Electronic distributor, our company has created a very small wasted spark ignition system for the Opel engine. It is currently under test and if all goes well, it will be available as a plug and play kit for your 1.9L engine.
    The kit will include the following:
    1) An aluminum single groove pulley (double groove and serpentine also available at extra $$$).
    2) A 6.55" Opel specific 36-1 trigger wheel.
    3) A PC-2 crank sensor.
    4) A logic level, 4-bank ignition coil with plug wires.
    5) An S-ECU Lite with a ready made Opel Specific harness.
    6) Tuning software with 10 sample Opel ignition tables.
    7) Distributor plug with oil pump drive (Optional).
    The target of this kit is for you to install and be able to drive your car within a couple of hours. Full step by step instructions done by Ivan (the crazy man) and will be a welcome addition to our product line.
    If you want to buy the individual parts, or source some of them yourselves, individual items will be available for sale at the website.
    dsmith likes this.
    www.edcatl.com
    Home of the S-ECU
    Apr 2003
    Portland, Oregon
    6,540
    Price point for this setup?
    Opeler V6Opel's Avatar
    Aug 2006
    Dayton OH
    95
    Mike Pilkenton
    Juan,
    So that we understand your systems better the S-ECU system you describe here requires the external crank trigger and aluminum pulley in order to trigger the system whereas the SS4 system uses a trigger internal to the distributor. Both systems will provide a wasted spark ignition system with the only difference being the S-ECU providing the added capability of managing a fuel injection setup if desired. Did I get this right?
    Mike Pilkenton
    70 GT - Corvette Yellow
    72 GT - Roadster, 3.1L V6, T5
    2008 Opel GT (w/ SKY badges)
  7. #5
    Oct 2005
    Acworth, GA
    3,088
    We have not fully priced it out but it will be under the $300.00 mark complete.
    Quote Originally Posted by V6Opel View Post
    Juan,
    Yes you do have it right, the SS4 is like the entry level system so you don't have to modify too much. But it is funny though, how many distributors out there measure load and temperature to get you the best curve, only mine I believe.
    www.edcatl.com
    Home of the S-ECU
  8. #6
    Jul 2005
    Milner, GA.
    11,260
    Dan
    12
    What's the best spark curve for
    ECT 130F, IAT 50F,2500 rpm and 40 gps air flow.....
  9. #7
    Oct 2005
    Acworth, GA
    3,088
    I guess my best answer would be to buy one, hook it up and find out
    GoinManta and hrcollinsjr like this.
    www.edcatl.com
    Home of the S-ECU
    1. Introducing the S-ECU Lite
      By blancojp (R.I.P.) in forum 1B - Ignition System
      Last Post: 02-16-2017, 09:12 AM
    2. Megajolt Lite Jr
      By garrymc in forum Opel Engine Performance Modifications
      Last Post: 03-08-2015, 10:12 PM
    3. clock lite
      By rbuhler in forum 1E - Other Electrical/Gauges/Instrument Panel
      Last Post: 11-29-2009, 01:59 PM
    4. Looking for '75 EFI ECU
      By IT Manta in forum Factory Fuel Injection
      Last Post: 11-06-2008, 07:52 AM
    5. Mini Lite style wheels
      By bret brummitt in forum 3D - Wheels and Tires
      Last Post: 02-01-2003, 06:10 PM
