Increasing Spark Plug Gap?
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By Viny Charb
Thread: Increasing Spark Plug Gap?
    Destiny is to Fly My location ronskydivepops's Avatar
    Mar 2005
    Sanford, Florida
    224
    CoolIncreasing Spark Plug Gap?
    I've just installed a pertronix ignition and flamethrower coil. Just wondering if increasing the spark plug gap will help. It's now set at .30 with new plugs. Compression is low (around 140) Just hoping to help burn off a bit of the oil that's blows by the rings, at least until I get my new engine built!! Thanks for any help
    Plano, TX 75074
    5,299
    Otto
    ExclamationPertronix plug gap
    Quote Originally Posted by ronskydivepops
    Due to the increased timing accuracy and reliability of the Pertronix trigger, even using a stock coil, I increase the gap to 1mm (.040" for the metrically challenged) and make the following modification to the standard Bosch W7BC plugs (99¢) I use:
    Hoosier Opeler Site Supporter My location rrossjr's Avatar
    Mar 2004
    indiana
    1,532
    Quote Originally Posted by tekenaar
    ... and make the following modification to the standard Bosch W7BC plugs (99¢)
    Otto, can you explain what you mean about improved flame front?
    Ron in Indy
    1000 Post Club My location baronbors's Avatar
    Dec 2002
    League City Texas
    1,126
    Quote Originally Posted by rrossjr
    Ron in Indy
    I'm guessing more exposed spark: ergo- more better combustion?
  7. #5
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    by opening up the plug gap there will be more load on the secondary..coil,rotor,cap,wires,plugs
    as the plugs get worn in a typical car the firing voltage goes higher and the burn time gets shorter "keep this in mind"
    ok time for a short story...when I was working for a Chrysler dealer back in the 80's
    customer would come in for a Tune-up we would pull out the worn spark plugs (over .045 gap)
    and install fresh plugs gaped at the factory spec .035 I might be wrong with the numbers been awhile lol
    anyway MANY of the customers came back with a lost fuel mileage problem after the tune-up
    regaped the plugs to .040 problem solved
    are the plugs getting oil fouled if so the oil rings may be frozen try some upper intake cleaner
    because 140 psi compression aint that bad
    Go for it and see what happens with the bigger gap
  8. #6
    5,000 Post Club My location namba209 (R.I.P.)'s Avatar
    Aug 2002
    5,893
    One of the tricks I used on my racing motorcycles way back in the 60s-70s, was to get a K-Mart brand, non Ford use 8 cylinder coil. There were many reasons, the prime being that brand coil would jump a 2 inch gap between electrodes during a test of coils conducted by a motorcycle magazine. They also had an idea that using an 8 cylinder coil, the time for coil saturation would be greater since we were only firing 1 or 2 plugs instead of 8 at the same RPM, and because of that, the coil would work nicely when the RPMs went into the 5 digit range. I would gap my plugs at .080" and never had a misfire. Using that ignition setup, along with a lot of other engine mods, I was able to get my Honda SL-90 from 55 MPH using a 15-47 final drive, to 70 MPH using a 13-70 final drive, with the RPMs up into the 14-16000 range. Also, I only had to change the points at the end of the racing season, and only because it seemed like the thing to do, they were not pitted or burned, just a little tarnished after a year of racing. HTH.
  9. #7
    Plano, TX 75074
    5,299
    Otto
    Flame front . . .
    Ron in Indy
    Rather than being partially shrouded by the ground terminal, it exposes more of the spark to the combustion chamber and 'lights off' the compressed mixture somewhat better . . . old Smoky Yunick trick from the '50s.
  10. #8
    Dec 2002
    League City Texas
    1,126
    YUH UH YUH UH- I was right- I win. I did win-didn't I?
  11. #9
    Member My location bosco's Avatar
    Nov 2003
    Las Vegas, NV
    456
    how does one do that unshrouding??? with a file???
    1973 Opel GT
    Previously:
    1971 Opel GT
    1973 Opel Manta
    1977 Datsun 280Z
    1993 Nissan 300ZX
  12. #10
    Plano, TX 75074
    5,299
    Otto
    ExclamationPlug prepping
    Quote Originally Posted by bosco
    I open the gap somewhat and then cut the ground strap, !!! VERY CAREFULLY !!! , with an angle grinder and finish with a hand file, again . . . carefully! I usually round off the new corners too and then gap to 1mm (.040").
  13. #11
    Nov 2003
    Las Vegas, NV
    456
    Thanks Otto...
    so it would probably be helpful for my set-up too...
    early 1.9 with flat top pistons, solid lifters, crane ignition, stock type coil (red label bosch i think), sprint manifold.......and the same .040" would also be appropriate??
    1973 Opel GT
    Previously:
    1971 Opel GT
    1973 Opel Manta
    1977 Datsun 280Z
    1993 Nissan 300ZX
  14. #12
    Plano, TX 75074
    5,299
    Otto
    Thanks Otto...
    Right on, Bro!
  15. #13
    Nov 2003
    Las Vegas, NV
    456
    Groovy....
    1973 Opel GT
    Previously:
    1971 Opel GT
    1973 Opel Manta
    1977 Datsun 280Z
    1993 Nissan 300ZX
  16. #14
    former opel racer My location jeff denton's Avatar
    Nov 2002
    near some glaciers
    2,736
    Jeff "Oh-Oh" Denton
    That's a neat tip, Otto. I think I'll play with that. Have you ever tried indexing the plugs, I wonder where the ground strap should point to get the most benefit of the theory...
  17. #15
    Old Opeler My location GTJIM's Avatar
    Jun 2003
    New Zealand
    5,565
    "J" gaps
    At one time spark plugs were available with the cut back side electrode - the theory being that the spark was more exposed to the combustion chamber and the sharp edge of the side electrode lowered the voltage requirement to fire the plug because electrons will depart from a sharp edge easier than from a flat surface.
    Indexing the plugs so the "open" side of the gap faces into the combustion chamber is another theoretical way of getting quicker and better flame travel through the combustion chamber. Though with the 'squish' type chamber the mixture is moved towards the flame front rather than the flame front having to travel.
  18. #16
    BDD
    BDD is offline
    Mar 2003
    Wisconsin
    1,176
    The sharp corners would be better for sparks to depart from. Pointed electrodes are best for that.
  19. #17
    Apr 2003
    Portland, Oregon
    6,666
    Adding to an old thread
    I was reading this thread and thought I might want to follow some tech advice in here.
    I took my relatively new plugs and checked the gaps. They went from 25-32.
    I regapped them to .035" and then used a dremel to, very carefully (I have 10X magnifying goggles I use), grind the ground strap back to about 1/3 of the electrode showing when I looked straight inline with the electrode.
    It makes sense to do this as it exposes a considerable larger portion of metal for the electrode jump the spark to.
  20. #18
    1000 Post Club Viny Charb's Avatar
    Oct 2007
    Ontario Canada
    1,280
    Cool little spark plug trick.
    First opel 1981 likes this.
    1. SSD Manifold
      By nobody in forum Opel Engine Performance Modifications
      Last Post: 04-12-2006, 05:44 PM
    2. No Spark to distributer cap
      By crliwa in forum 1B - Ignition System
      Last Post: 07-26-2005, 11:48 PM
    3. Performance Spark Plug Wires
      By soybean in forum Opel Engine Performance Modifications
      Last Post: 09-09-2004, 01:40 AM
    4. Plug Gap?
      By greensmurf20 in forum 1B - Ignition System
      Last Post: 09-05-2004, 01:32 PM
    5. spark plug / ignition question
      By GT_Pheel in forum 1B - Ignition System
      Last Post: 04-30-2004, 08:53 AM
