Distributor rebuild thread. (questions) - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Like Tree4Likes
Thread: Distributor rebuild thread. (questions)
  1. #21
    Apr 2003
    Portland, Oregon
    6,666
    Done, except magnet on the lobes and E-clip on the vacuum advance
  3. #22
    Jul 2005
    Milner, GA.
    11,300
    Dan
    12
    Good reason to go to a fully electric sparf curve I would say.
  4. #23
    Mar 2012
    Scottsdale, Az
    1,723
    And just what is it you have "done"? Pertronix, Dr. Juan, or ??? I have yet to do my distributor and it was sent to the good Dr (RIP) a few months ago so ??? It is not important as it was a "spare" that I was going to finish, then swap into the installed motor.
    Doug
  6. #24
    Apr 2003
    Portland, Oregon
    6,666
    Doug
    That is my spare Pertronix. The good Dr Juan (RIP) had my magnet for this unit, along with my other distributor and a couple thermostats.
    I have decided that, since I may never hear from or see my parts, that I can buy a replacement magnet or try to build my own. I'm actually working on the magnet now (as in I took a break to check this forum). I have the drawing for the magnet housing and little magnets on the way from some other country. I won't be able to finish the magnet for a couple weeks because of the shipping delay.
    My first incarnation of the magnet housing was off by .05mm (too small). The next one should fit better.
    I'm toying around with making a wasted spark pick up. I don't know how accurate the signal will be so I will have to test it before actually installing it in a car. Simple design, though. Two pick up units at 90 degrees to each other and a double sided magnet (as opposed to a four sided one). Long way off, though.
    1. Comments Thread - Building a distributor with the EDC-SS1 Electronics
      By blancojp (R.I.P.) in forum 1B - Ignition System
      Last Post: 05-04-2016, 11:53 PM
    2. Getrag Rebuild Questions?
      By nobody in forum Clutch, Transmission and Drive-train Upgrades
      Last Post: 12-22-2015, 07:15 AM
    3. Stupid questions thread.
      By MonkeyNutZ in forum General Discussions
      Last Post: 04-19-2010, 12:36 AM
    4. Delco-Remy Distributor rebuild
      By gr_diver in forum 1B - Ignition System
      Last Post: 02-16-2005, 04:51 PM
    5. Head Rebuild Questions
      By Scott McDonald in forum 6A - Engine Mechanical
      Last Post: 05-28-2004, 05:38 PM
