Distributor rebuild thread. (questions)
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Like Tree4Likes
Thread: Distributor rebuild thread. (questions)
    Apr 2003
    Portland, Oregon
    6,540
    First off, I will post pictures later but tonight I'm wondering if there's a special trick to get the small circlip into the top of the distributor to hold down the stuff inside the distributor?
    Getting it out was relatively easy, once I finally found the clip in another room of the house...
    Apr 2003
    Portland, Oregon
    6,540
    As promised, pictures.
    Here's what the inside of the distributor used to look like.
    Here's what it looks like now. And the clip I can't seem to get into it's lock place.
    Made a special tool to put the clip in. That didn't work. Any ideas would be awesome.
    Nov 2007
    Cöllingswööd, NJ
    9,689
    Gördö
    6
    I'm not 100% sure that I know what you're talking about, but I assume it's a clip around the shaft at the top. The thought occurs to me that you might be able to get it started on the shaft by using an old rotor to push it on.
    I used to have to work with C and E clips a lot. I, too, have had them go flying, never to be found again.
    The "special trick" of which you speak is to have a whole box of 100 new clips to replace the 5-6 that you'll lose trying to get just one of them on.
    Nov 2007
    Cöllingswööd, NJ
    9,689
    Gördö
    6
    Oh, I see your pics now. Man, that is a real bugger of a clip location. Maybe spit on a small socket, Bic pen, nut driver, or some other tubular item and stick the clip to the spit and quick push it on?
  7. #5
    Jan 2003
    Chapel Hill, TN
    7,790
    Harold Collins
    Two small screwdrivers always worked for me. Just hold one end down and walk the other in place.
  8. #6
    Spofford, NH
    12,451
    Bob Legere
    90% of the time I'd use a tiny pair of needle nose pliers I own, but I seem to recall I had some thinwall tubing which made the job a lot easier....when I could find it.
    Gary likes this.
  9. #7
    Swansea, MA
    8,988
    Gary
    4
    And you usually find it a week AFTER you needed it!
    www.alt-opel.us
    @opelgary
  10. #8
    Apr 2003
    Portland, Oregon
    6,540
    I never lost the clip!!!
    So, while at work, I was thinking I could just make a clip spreader. Easy enough, right?
    I already had the normal C-clip type spreader so I thought I'd just modify it. It's a cheapo Harbor Freight version so it wouldn't matter if I messed it up.
    I started with a small engraver bit.
    Did I say small? It's friggin TINY!!
    (Dremel item 106, in case you are wondering)
    And went to grind a small recess in the back of the c-clip spreader.
    To get this nifty little tool.
    Continued below...
  11. #9
    Apr 2003
    Portland, Oregon
    6,540
    Next I looked at the clip and saw that the sharp profile was on the inside of the clip.
    That won't work as the tool would be between the shaft top and the clip. So I ground a new point on the clip using a metal cutting blade on the Dremel to get this
    That's more like it. Now to fit the clip onto the spreaders. OOPS, it doesn't quite fit.
    So I took the little grinding wheel, on the dremel, and removed some of the metal from the spreaders. Now it fits!!
    And it's held in place perfectly!!
    And then I spent the next 20 minutes trying to get the stupid clip on the stupid shaft and nothing I did would allow the spreaders to open far enough to get the clip on. It kept slipping and turning vertical.
    So, I gave up and made a different tool.
    If you read this far, do NOT bother with the stuff above.
    Here's the tool I made. It's a simple aluminum sleeve that, literally, pops the clip right on in less than a second.
    I added the dimensions in case anyone needs to make one of these.
    And I'm so glad for the little tool and the ease in which it works BECAUSE....
    I forgot to put the little washer on the top of the shaft before installing the clip. Without the little washer the advance mechanism just slides right off as if the clip wasn't there.
    So, I pulled the clip back off and added the washer. Then used my new tool to, once again, pop the clip on in less than a second.
    BTW, if I had the washer on there in the first place, I probably could have done it without the silly little tool but it still would have taken some time. The missing washer was what allowed the clip to slip off the shaft and down next to it.
    Thanks for the input, guys.
    guyopel and The Scifi Guy like this.
  12. #10
    Mar 2012
    Scottsdale, Az
    1,680
    Next I looked at the clip and <SNIP>
    And <SNIP>
    OK First, I've gone a little cross eyed looking at the tool! Is there a slight bevel on the end or is the edge square? I'm thinking a bevel helps spread the clip so it starts easier. Without the bevel I would think it would still be hard to start? Either way, I like simple!
    Doug
  13. #11
    Apr 2003
    Portland, Oregon
    6,540
    Doug
    What I did was run a cutting tool in the material area of the "ring" of the tool. It's actually concave, although it looks beveled. I did it freehand on the lathe just cuz it didn't need to be deep.
  14. #12
    Mar 2012
    Scottsdale, Az
    1,680
    Cool! -- Doug
  15. #13
    Non Civilian My location opelwasp's Avatar
    Mar 2003
    Between Chico and Sac, CA
    2,029
    I'm interested in one. You mind making one for me and I'll paypal you $10?
    1971 GT (Opelwasp)
    1974 Manta A (Polizei)
    1973 Manta A (junker)
    1973 GT (junker)
    2001 Dodge Durango SLT 4x4
    2004 Dodge Neon SXT
    2002 Suzuki SV650S
  16. #14
    Apr 2003
    Portland, Oregon
    6,540
    Quote Originally Posted by opelwasp View Post
    Well, I hadn't really thought about making them for other people but it's easy enough to make another (just finished it). I'll PM you.
  17. #15
    Opeler jmbinjax's Avatar
    Mar 2005
    Canton, GA
    699
    John
    I think I used a long 3/8" socket. Between metric and SAE I think you could find just the right size. IIRC
  18. #16
    Mar 2012
    Scottsdale, Az
    1,680
    Quote Originally Posted by jmbinjax View Post
    That hole is 1/4" (0.246 actual) and the OD is 3/8" (0.374) so that will be a really thin wall socket (the 1/4" is measured across the flats remember). However, if you find the 3/8" OD with a smaller opening, you might be able to drill it out to 1/4". HTH -- Doug
  19. #17
    Mar 2005
    Canton, GA
    699
    John
    Good point. I can't remember what I used then, but I do know I found something laying around to push it on without too much difficulty.
  20. #18
    Aug 2002
    SW Missouri
    2,252
    well I found a socket that worked too.
    jmbinjax likes this.
    TMK
  21. #19
    Mar 2012
    Scottsdale, Az
    1,680
    Quote Originally Posted by tomking View Post
    And the size is/was ...?
  22. #20
    Aug 2002
    SW Missouri
    2,252
    I dont recall as it has been a few years.
    TMK
    1. Comments Thread - Building a distributor with the EDC-SS1 Electronics
      By blancojp (R.I.P.) in forum 1B - Ignition System
      Last Post: 05-04-2016, 11:53 PM
    2. Getrag Rebuild Questions?
      By nobody in forum Clutch, Transmission and Drive-train Upgrades
      Last Post: 12-22-2015, 07:15 AM
    3. Stupid questions thread.
      By MonkeyNutZ in forum General Discussions
      Last Post: 04-19-2010, 12:36 AM
    4. Delco-Remy Distributor rebuild
      By gr_diver in forum 1B - Ignition System
      Last Post: 02-16-2005, 04:51 PM
    5. Head Rebuild Questions
      By Scott McDonald in forum 6A - Engine Mechanical
      Last Post: 05-28-2004, 05:38 PM
