Unanswered: After Market CHMSL (Center High Mount Stop Lamp)
UngerDog
I don't know about aftermarket kits. I used one from a Lincoln Mark VII that turned out very nice. I screwed mine into the shelf below the rear window which was easy since the rear glass was out. I guess you could make a plate under the light and double stick tape to it. But you will need to ground the light frame and use a rear stop light wire to make it work. You can pick one up at a wrecking yard for maybe $5. Jerry
There was a project by JJ a few years back to put LED strip in the rear vents, I don't know he has any left.
http://www.opelgt.com/forums/1c-ligh...ear-vents.html |
Trouble Maker
Real Name: Tony Holcomb
CHMSL 3rd Brake Lamp Light
I always forget proper CHMSL description and use 3rd brake light for SEARCH.
Some Searches work better with lamp or light. www.jcwhitney.com 20-led Third Brake Light ZX123032W Each $14.99 On the larger JC Whitney picture, appears that glass angle is more vertical compared to slant of GT rear glass. Glass-mount Light ZX126698A Each $10.99 This looks like better glass angle for GT, but appears to be bulb instead of LED. Installation of DESTEC LED Lamp that mounts in rear window vent of GT is slightly involved: Requires drilling hole through GT roof support when headliner is removed. Wires need to be fished under headlinner, etc. On my list of projects to accomplish ... Someday! |
I was doing some researching just yesterday for a 3rd brake light and came across with this link: Third Brake Lights, LED Third Brake Lights from Command Electronics
Hope that helps there are somes different angles listed, I have yet to get the protracor out of the drawer and check yet, maybe tomorrow.
Dave 73 Opel GT-work in progress 74 Manta 75 Manta Previous 72 Manta Rallye-owned 1974-1979 |
