Unanswered: Most common electrical problems...
I've only had one real severe electrical problem on a stock GT, and it was a sweetheart. I was tuning the engine on Willit?, with it running, timing lite, dwell meter, the standard stuff all hooked up. Smelled wiring burning and sure enuff smoke was rolling out from under the fuse panel. I shut down the engine and disconnected the battery post haste, but not fast enuff. The whole fuse panel was toast along with 80% of the wiring. It turned out, the resistor wire to the coil had just been stuffed in the power panel area and years of constant vibrations had finally worn away the insulation, right next to the 4 studs in the center of the panel. One thing led to another and shortly the insulation melted away from a ground wire and the whole mess went up in smoke. 3 days to remove a harness from a donor car at the recyclers and 5 days to repair and replace what was gone. Got an electrical education on that one.
The only electrical gremlin was the famous "double green" of the turnsignal dash indicators. Permanently resolved, thanks to DESTEC
Destiny is to Fly
I don't even want to mention my electrical problems!! My Gremlin might wake up and start causing me some problems this weekend when I go for a ride. He only seems to pop his ugly head up when the strereo is on and I hit the brakes as I turn on the left blinker and then blow a fuse. Did I mention it has to be the 3rd Sunday of the month, and there has to be a 30% chance of rain. I just carry a pack of 30 amp fuses. It only happens once in awhile, but it still bugs me. If I want it to happen it won't. I took a 1500 mile round trip to Richmond, Va. and it didn't happen. Next day I went to the store and I blew a fuse right away.
Real Name: Brett
Biggest problem I have run into myself though, is ground issues, especially the frame to engine ground that gets so often overlooked since it is rarely ever touched. But like you said in your plan, cleaning all your connections is a great place to start... 30+ years of vibrations and oxidation etc eventually takes it toll. |
http://www.opelgt.com/forums/group-1-electrical/ i read every post when i was a moderator to clean out the junk , took some time and i think the most common post was from ron (namba 209) as an answer and it said in various ways " clean and check the grounds to the chassis and fuse box" i think that covers 99% of the problems with opel electricals
Reading Ron's electrical disaster with resistor wire from coil -WOW!
I replaced all factory fusible links and replaced headlight wires forward of the crimps near master cylinder. Have "green knob" shut-off for battery ground. In an electrical emergency, it would be tricky to stop GT, open hood, and reach inside battery cavity to shut off ground connection. GT Owner installed "Maxi Fuse" holder (30A to 80A) near coil mount. Maybe it was intended as fuse for the alternator hot lead? Might be somewhat easy to pull-out "Maxi Fuse" in holder in an electrical emergency. DC Circuit Breaker would accomplish the same as fuse. Battery Master disconnects are big and bulky. Last edited by Lindsay; 04-14-2007 at 05:09 AM. |
ALL and I do mean ALL of my wiring behind the dash was rotted and falling apart. I must have had the panel out 10-12 times per year over 2 years. Got real ggod at pulling it out- think my record for dropping the steering and pulling the panel was 12 minutes. Finally bit the bullet and took 3 weeks out of my summer vacation to completely replace each and every wire behind the dash along with several wiring modifications and improvements (now use modern fuses insted of the ceramic ones) Well worth the time as no more problems. Now watch - as soon as I get the new clutch in the wiring will act up again.
![]() BTW- welcome back BAZ
Texas Opel Preservation Society Last edited by baronbors; 04-14-2007 at 11:45 AM. Reason: additional text |
I think, Lindsay, I'd put the "Green Knob" on the positive lead of your electrical system. We've heard the stories where grounds to circuits were made using other system's grounds causing all kinds of troubleshooting havoc. As for having a real close system shutoff, an idea would be to have the red wire from the starter solenoid go through a 50 amp circuit breaker, then to the stud it is normally attached to, that would theoreticly turn off everything. But with trons, who knows.
Ron 72 GT 3.4L V-6/T-5/ZF posi - almost done - Just need AC installed. ![]() 75 Chevy monza 5.7L/TH350/Auburn 3.08 posi - Next Last edited by namba209; 04-14-2007 at 02:37 PM. |
It doesn't matter if it's on the positive or negative lead, as long as the battery is cut off from the electrical installation, but if you really want to go on the safe side use a switch or some thing similar to cut both battery leads off from the electrical installation
#15 (permalink) | |
eBay Motors: JAGUAR LAND ROVER MORGAN BATTERY CUT OFF KILL SWITCH (item 120107096007 end time Apr-15-07 17:36:43 PDT) |
