Unanswered: Fog/Blinker housings bolts?
PO had unplugged the running light from the side banana lights, left it lay and run the blinker wire up there. I'm reversing this back to what I think is normal; front cans are blinkers, side lights are parking/running lights.
The are M4 x .7, get yourself a set of taps so you can clean the threads out, probably just rust.
check off another from the to-do list
I ended up popping out the blind nut holders, come to find out they're just clipped in. One had a busted off bolt stuck in it anyway. Used regular nuts and bolts with lock washers. Got blinkers and running lights working as Opel intended (at least on this side of the pond).
What a good feeling to put something "back to rights" so to speak. Now for the backup light. That housing was off when I got the car, put it back on, found the wire (no ground? just grounded through chassis?) while redoing tank vent lines, hooked it up but it doesn't work, probably on the switch side, wherever that little bugger is hiding on the tranny. Come to think of it, I didn't check the bulb.....
Check for 12V with the car in reverse on the wire to a good ground. The fixture itself goes bad, just like everything else in the car, due to corrosion.
Come to think of it, that is a very unique bulb, one of the early halogen types, it has the same appearance as the fuses, just a bit larger. It is held in place by the ends, so only the pressure of the contact clips make contact. Check those for corrosion also, as well as the screws that attach the base plate to the body. HTH.
Can I put this as a new thread with the proper title so the next guy can find it? I will. PS I tacked this post onto the end of a backup light thread--this is 1970 4 speed, apparently after 1970 the backup light switched to a cylinder style and a different location on the tranny......
"Being ignorant is not so much a shame, as being unwilling to learn." Benjamin Franklin Last edited by jvandyke; 04-22-2007 at 12:06 PM. |
