Old 08-28-2007   #1 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Unanswered: High Beams Go Out
Does anyone have an idea as to what would cause the headlights to go out when the dimmer switch is switched to high beam? Any thoughts would be greatly appreciated...
Roy Bell
1973 Opel GT
74 Manta Rallye
Concord, North Carolina
Carolina Opel Club
OMC
Ooooner is offline
Old 08-28-2007   #2 (permalink)
VT_GT's Avatar
VT_GT is on a distinguished road
Have you rewired the headlights? If the wire going to the high-beams is bad and shorting out, that would cause the same issues. You can also check at the relay to see if you're getting 12V out to the white wire when the high beams are turned on.
'73 Opel GT, 4-speed: daily driver
'67 Dodge Dart, 471 stroker: 11 second daily driver/bracket racer
VT_GT is offline
Old 08-28-2007   #3 (permalink)
opelspyder's Avatar
White wire
Check the white wire at the headlight relay and make sure it is hooked up as well. If all looks good, maybe check that green ground wire that controls the switching to the high beams
Keith
opelspyder is offline
Old 08-28-2007   #4 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Yes, the headlights have been rewired and they have been working perfectly for a few years now. It just started this week. I will check the wires both of you have suggested. Thanks!
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-28-2007   #5 (permalink)
dcm013's Avatar
dcm013
When mine did that I had to replace the relay.
Don
dcm013 is offline
Old 08-28-2007   #6 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Don,
OK, this may sound dumb but where is the relay that you replaced located?
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-28-2007   #7 (permalink)
Roy, both headloight relays are behind the fuse panel and are held on to studs with 10mm head nuts, IIRC. The Green wire as stated operates the relay from the dimmer switch, the White/Yellow is the power wire to the relay as well as the microswitch in the right hand bucket, when the relay is activated, the relay switches to low beams, via the Yellow wire or high beams via the Yellow/White wire to the headlights. HTH.
Old 08-29-2007   #8 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Ron,
Thanks for your help once again. I will start digging into the problem this afternoon!
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-29-2007   #9 (permalink)
soybean's Avatar
Roy, check out this Thread. Post nos 8 shows the relays to give you a better idea what to look for. Hth, Jarrell
soybean is offline
Old 08-29-2007   #10 (permalink)
opelspyder's Avatar
Yellow and white wire
In Destecs wiring diagram it states you can remove that yellow and white wire all together as it is not needed. What then allows the relay to work if they will only work if the headlights are in the up position?
Keith
Old 08-29-2007   #11 (permalink)
Keith
Keith, JJ suggests the White/Yellow wire to the microswitch be removed. It is a power source for the headlight indicator bulb that actually doesn't do anything once both headlights are locked open, but does power the bulb if the left headlight is not locked open. The White/Yellow wire from the headlight relay to the high beam relay, powers the headlights, both high and low beam and JJ suggests a fuse in that wire between the two relays. Hope this clarifies it a bit for you.
Old 08-29-2007   #12 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Jarrell and Keith,
Thanks for the additional information. I will be looking at this problem today and see what I find out... Again, thanks to everybody.
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
