Old 09-01-2007   #1 (permalink)
RckymtnOpel
Unanswered: bad Halogen replacement?
I put in some Halogen lights after my rewire... it seems that they work even though i put the wires in the wrong order in the back of the bulb....
see pdf
http://www.opelclub.com/GTHeadlightsAugust2004.pdf
also here is a pic of the brand i bought no research really $24 each at checker and i think they are quite a bit brighter...
http://www.opelgt.com/photos/showgal...0&ppuser=14699
does anyone think these might pull to much power or be a problem??- hope someone can let me know because i plan on driving for two hours tomarrow up to 10,000 ft
yes i know i should upgrade to relays but im not doing that for another week or two.
tomorrow im going to move the wires so they are...
left ground
top yellow low beams
and right white high beams
(view from back of bulb)
Last edited by tekenaar; 09-01-2007 at 02:11 PM. Reason: seams - clothing, seems - appears, resurch?
RckymtnOpel is offline
Old 09-01-2007   #2 (permalink)
BMWonly's Avatar
I haven't converted my GT lights yet, but I am running halogens for 2 years now and 25k miles in my 1973 BMW 2002 (same weak electrical system), and it's working great, much brighter with the 55/65 watts. Using the 100W lights will most likely cause problems without a relay.
Dieter
BMWonly is offline
Old 09-01-2007   #3 (permalink)
RckymtnOpel
yeh these are 55/65 watts as well... you know i noticed my lights are on when the buckets are down and its probly cus the wires arnt in the right spot... thanks for the info bud
Old 09-01-2007   #4 (permalink)
Me too, been running the replacement halogens in both my cars for years with no problems. And on the Opel that was with the original alternator, until I did the engine swap.
