Unanswered: Low beam ,night lights
My bet would be that a couple of the wires have been swapped on the rear of the headlights. I would also check the grounds which is probably not the problem since the high beams work.
Harold |
Since high beams are OK your lamp grounds are good. I would measure voltage at the lamp socket with high beams on (high beam lamp terminal to ground) and then measure low beam voltage (low beam lamp terminal to ground). My guess is you have a high resistance on the low beam circuits somewhere. Check low beam voltage starting at the lamp working toward the headlamp relay and fuse panel. Good luck. Let us know what you find.
More than likely it is bad contacts inside the relay. Take it out, open it up and check the contacts. There is a good chance you can just file the contacts clean and fix your problem.
#7 (permalink) | ||
If the relais doesn't work good buy a new one, for the few bucks those things cost.
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 10-07-2007 at 03:25 PM. |
