Opel Forums
Go Back   Opel Forums > Technical Forums > The Main Tech Forums > Group 1 - Electrical > 1C - Lighting and Signal Systems
Old 09-04-2008   #1 (permalink)
ben
ben's Avatar
ben
Unanswered: hyper turn signal flash
my turn signal flash so fast replace the flasher and light's
any help would be great
also every time i turn on my headlight or heater car stall's replace volt reg still do the same thing
ben is offline   Reply With Quote Top home
Opeler Forever,
Ben
Old 09-04-2008   #2 (permalink)
guyopel's Avatar
Classified Rating: 100% (1)
guyopel
Have you tested the Alt. output and what were the results ?
guyopel is offline   Reply With Quote Top home
Guyopel
---Thomas Edison
Old 09-05-2008   #3 (permalink)
I had a student with similar problem on a not that old Dodge truck. When he turned his headlights on it stalled the engine. It turned out to be a ground issue in his case.
I would do the Alt. check first as suggested and then check my electrical connections. Ground connections are just as important as the positive connections.
Old 09-05-2008   #4 (permalink)
jlthunder's Avatar
Is this the stock flasher unit or did a PO install a replacement? The incorrect flasher unit can cause this.
This was commonly seen when someone wired up a trailer which puts more load on the flasher unit and it blinked at an extremly fast rate. Normally, at least in old cars, a HD flasher unit is installed if a trailer is hooked up. An incorrect flasher unit can cause this.
In new cars, the computer controls the flash rate and if a bulb burns out, it flashes faster than normal, but Opels don't have computers.
jlthunder is offline   Reply With Quote Top home
1973 GT, Parted out, R.I.P.
Old 09-05-2008   #5 (permalink)
Kalifornia Kid
DennisGardiner's Avatar
I would concur. You have a bad electrical problem, that most likely goes beyond an alternator issue.
Any car, with a well charged battery,... will be able to drive for many miles before the battery runs down and the car stalls.
My old 72 Kadett made it back from Little Rock, AR to Tulsa, OK on an alternator that went out on me the night before.
Check all power connections and ground connections with a voltage drop test.
This is done, for example on a battery cable by placing:
a. the positive lead of a volt meter on the battery + terminal
b. the negative lead of a volt meter on the starter + terminal
c. crank the engine (ie. load the system)
= You sould see no more than a maximum of 0.2 volts
What does this mean? A voltage lead from one end of a wire to the other end of that same wire read the voltage loss (wasted or not available to the starter).
This same test (as well as others) can be used to pin point your electrical problems.
DennisGardiner is offline   Reply With Quote Top home
Just a good ol' boy. Never meanin' no harm.
