Unanswered: Headlight High Beam
yes, unless it is an early model 69 some of those have a push button on the end of the turn signal arm the rest flip forward or back with turn signal lever to change from hi to low beams
#3 (permalink) | |
![]() Harold |
Pulling the stick toward you is just a momentary contact and for the most part makes no "click" at all. The special relay that Opel uses for the high/low beam has a latching mechanism in it, sort of like a bathroom cabinet door that you have to push to latch and then push it again to unlatch. If you can't get high beams and you don't hear a click from the relay then either you have a wiring problem or you have a bad relay.
Jeff '73 GT,5spd,Recaro,EDIS4 2.2 EFI by MegaSquirt, Ali Flywheel w/S10 Clutch, Electric Fan, Roller Rockers, Venolia Pistons, 6 Cyl Intake w/ Custom Injection, 15" Wheels,Lecarra,F&R Sway Bars,Custom Exhaust,1" Sport Spring,Koni Reds,Big Brakes,3 Core Ali Radiator,Hse of Colors Kandy Pagan Gold. 123 WHP @ 6800 RPM ![]() '64 VW Karmann Ghia '08 BMW M3 Last edited by markandson; 02-06-2009 at 11:01 PM. |
