thescifiguy
Real Name: Gordon Payton
Answered: Simplified headlight wiring
I'd like to do this modification to my new GT, but I'm told that I can't just wire the headlights to the switch 'cuz it can't handle the power. I guess it might be able to be done using the existing headlight relay or maybe another relay like the ones we add to bypass the ignition switch. Can an electrical Guru out there suggest the wiring sequence to pull off this sort of modification?
Most Helpful Answer - Posted by thescifiguy
Success!!! I tried the gray/red wire straight to the headlight relay trick and I got nothing. After looking at the factory Opel repair book's wiring diagram, I saw that power comes from the parking switch and goes through SEVERAL different fuzes in thje block. Since I knew that attaching a wire to either side of the first fuze, as indicated in reply #3, somehow was creating a holding circuit that kept the headlights on all the time, I went back to the basics of what I knew: Some mechanic, probably without the help of a wiring schematic, somehow got the headlights to come on WITH the parking lights. So what did he probably do? He probably probed around on the fuze box looking for a circuit that went hot when the parking light switch was flicked. There are several. I found that the second fuze went hot also. I found an unused terminal and connected a jumper from there to the yellow/black wire spot on the headlight relay. Viola! Headlights go off and on with the parking lights! So there you have it: No messing with gray/red wires, just unplug and tape off the yellow/black wire on the headlight relay and run a jumper from that terminal on the relay to the second fuze. |
I think this has been covered but if I recall I remember a lot of reference to:
Daniel Stern Lighting Consultancy and Supply
Dave 73 Opel GT-work in progress 74 Manta 75 Manta Previous 72 Manta Rallye-owned 1974-1979 |
Should be very easy to do I don't have a schematic with me but I'm sure someone else will chime in, if not I can help you in a few days.
Uber Genius
A quick look at the wiring diagram suggests the following easy connection change will work (in theory, because I haven't tested it yet) 1) Disconnect the yellow/black wire from the headlight relay and tape off Wiring1.jpg 2) Connect a jumper from the disconnected lug in step 1 and connect the other end of the jumper to the fuse block position as shown in the attached picture Wiring2.jpg That should do it
Find the yellow wire with the black stripe on the headlight relay, pull it off and tape it up, this is the wire that becomes "hot" when the micro-switch is activated by the headlights being open. Find a wire at the fuse box that is Grey with a red stripe, which should be at the second fuse, this is the wire that feeds the front marker lights, run a jumper from this spot over to the terminal on the headlight relay. That should do it, you will now be powering up the headlight relay whenever you turn on the marker lamps.
Uber Genius
That should work too though, in theory, you are now powering the headlight relay through the marker lights circuit.
Yup, that is exactly what I am trying to do.
#9 (permalink) | |
Uber Genius
On the wiring diagram I am looking at (I believe its the MEGA wiring diagram) the running light switch is the point that he should connect to. Running it through the running lights themselves will work, as I said in my reply to your suggestion. I just thought it would be better to go all the way back to the switch for the power source for the relay. I might have read the running light switch wrong, and if I did I will concede.
No conceding necessary one way or the other, we are both just trying to help a fellow Opeler.
Me either, why mess with the way the system works if all you need to do is supply power to the headlight relay from a different source?
thescifiguy
Full power through the switch?
So, are we running the full power for the headlights and markers through the switch or is the main current flowing through the relay and the switch is just enabling the relay? The latter set up being the more desirable option.
By the way, THANKS GUYS for saving me the trouble of working out the circuit myself!
thescifiguy
making a holding circuit
Well, guys, I tried the jumper wire from the indicated fuze box location to the yellow/black location on the headlight relay and what I get is a holding circuit that won't turn off.....even with all switches off and the key removed, the headlights won't turn off until you unplug the wire. Put the key in, plug in the jumper wire-----headlights are still off-----advance key to the run position---lights are still off----- flick the parking light switch and all the lights come on. Now you can't turn them off. Flick the switch, remove the key, they're still on. I even tried a different fuze/location on the fuze box and it still happens.
I tried this a buncha weeks ago when you guys gave me the info and the same thing happened. I thought I'd check out the wiring before I got us grasping at straws. I'm pretty sure things are right. Any ideas?
#20 (permalink) |
i pulled one of the parking light wires from the fuse box and plugged it into the y/b position on the relay. when you flip the parking switch it now sends a current to the relay to trigger the headlights. no jumpers or wires to cut but you have to have enough slack in the parking light wire to reach the relay.
good luck! bob |
#21 (permalink) | |
hEADLIGHT PUZZLE
#22 (permalink) |
thescifiguy
hmmmm
That's essentially what I did, except I put a double terminal on one of the spade tips sticking out of the fuze box(where a grey w/red wire was) and then just simply ran a jumper wire from the extra new spade tip to the yellow/black wire location on the relay.
Hmmmm......does this only work if I remove the wire from the fuze block ENTIRELY and plug it into the relay???? But the wire is attached to the fuze box for a reason: to get power from the fuze box to feed that part of the parking circuit. Is the grey/red wire you removed and plugged into the relay getting it's power from the relay? If not, then shoudn't some of the parking lights go out?
#23 (permalink) |
no, everything seems to be working normally with all lights functional. there is a prior thread that i started when i was having problems and i asked for help troubleshooting. ron (namba) helped me figure out which wire to pull. i don't have my chart with me otherwise i could tell you which one you need to pull.
remember that the parking lights also receive power from the headlight relay when it's activated so pulling the wire doesn't affect their ability to light. |
#24 (permalink) |
thescifiguy
I'll give it a try
Okay, tomorrow I'll unplug a grey/red wire from the appropriate fuse location and plug or extend it directly to the yellow/black wire's relay location.
#25 (permalink) |
The yellow/black wire coming from the micro-switch to headlight relay is the B+ for the field coil with the ground side being the brown wire.
Which runs straight to ground. Theres two ways to control the field either power or ground to light up the headlamps. |
