Unanswered: what is it and what's it do !!??
![]() Ok question number 2 .... the headlight knob also turns .... what does that cause ... again tried it over and over and there seems to be nothing that it does .... ????? any info would be great.Thanks in advance Last edited by tekenaar; 07-12-2009 at 10:47 AM. |
UFO pel abductee.
The knob under the seatbelt light is a dimmer for the insterments lighting,
but often fails. I simply wired mine full bright as suggested by someone here since it no longer worked. Turning the headlight knob does nothing as far as I know. I've owned two new ones, a '73 Manta and a '75 1900 sedan.
#3 (permalink) | |
UFO pel abductee.
![]() Sooo....The knob under the seatbelt light is a dimmer for the insterments lighting, but often fails. I simply wired mine full bright as suggested by someone here since it no longer worked. Turning the headlight knob does nothing as far as I know. I've owned two new ones, a '73 Manta and a '75 1900 sedan.
Real Name: Jim
![]() Provided Answers: 7
Everything said so far is correct.
Just to add, turning the headlight knob activates a spst switch on the back of the light switch that isn't connected to anything. There are two unused lugs back there. It was never used in any application I know of from Opel, but someone, (I forget who) used the contacts on the back to run a pair of under-dash courtesy lights they wired themselves, pretty clever. But, if you do the same, remember that the switch does not not run through the ignition switch, so you'll also have to remember to turn off your courtesy lights or they'll be on all the time. You could also use this switch (with a relay) to run things like a fuel pump or driving lights. Jim
For future reference, please do NOT post multiple posts on the same topic. One post per topic, as per the guidelines. For your future posting reference, please refer to: http://www.opelgt.com/forums/general...ease-read.html and the classic http://www.starterupsteve.com/swf/posting.html
try turning the headlight knob all the way clock wise with doors closed and see if it truns on the dome light. when the knob gets to the stopping point, try and turn it just a little bit more. i had a 85 AMC eagle and it has a headlight knob like that, and it was also the dome light switch.
Manta Maniac
On the 'B' series cars, it turns the interior light on and off...on my UK cars I think it turns the dash lights on and off...it's been a while so I'll have to look again.
As a side thought, it's a good way to add an immobilsor switch...
Politicians and diapers have one thing in common. They should both be changed regularly and for the same reason. |
Adding to what Mark posted, yes, the knob under the "Fasten Seat Belts" is for the bright/dim of the dash lights, and as Mark has posted, most are so old now, they don't work, best to straight wire. This knob applied to the 74-75 models, both Mantas and Asconas. The Headlight switch being able to turn was for the 71-73 models, but, instead of dimming, they were either on or off. Opel just didn't change the design of the switch for the 74-75 models. (Just being frugal
#11 (permalink) | |
UFO pel abductee.
