Old 03-17-2006   #1 (permalink)
EJprovost's Avatar
EJprovost is on a distinguished road
Unanswered: Blinker switch plug (signal double blink fix)
I have a question for anyone who has the wiring chart from Destec. On the blinker switch plug: Is the view on this plug from the side that the wires go into it, or is it a view of the side the blinker switch plugs into?
Second question: Is it a good modification to change to a two prong blinker switch? Does any two prong work, or is there a specific one recomended?
"Enjoy The Ride!"
1969 GT, 1973 GT "Quazar"
1995 Camaro Z28
New Birthday presents for daughters:
1970 GT, 1971 GT
EJprovost is offline
Old 03-17-2006   #2 (permalink)
Blinker Thingie
JJ Wheatly makes a blinker 'fix-it' kit too that eliminates the GT "double blink" problem and up grades the system.
Good question about which end the drawing views the wires from - needs a bit of investigation......
Old 03-17-2006   #3 (permalink)
Liz, I just checked Willit?'s instrument panel and the plug in question is shown, on JJ's schematic, looking from the bottom where the wires go into the plug. In the notes on the schematic he suggests mods for either a 2 or 3 pin flasher willl work. Which ones IDK, I'm still using the original 4 pin in Willit?, at least it worked 12+ years ago. HTH.
Old 03-17-2006   #4 (permalink)
EJprovost's Avatar
Thanks everyone! My wires are in backwards then (lower two). Could this be why my turn signals don't work?
"Enjoy The Ride!"
1995 Camaro Z28
1970 GT, 1971 GT
Old 03-17-2006   #5 (permalink)
Liz, look at the schematic closely, you'll see that the pins are oriented such that the wires should only go in one way with the horizontal pin being closest to the instrument panel, or the bottom of the plug, and the Brown wire, looking it the bottom of the plug, goes on the right side. That puts the Black/Red wire on the left side, the two Black/White/Green wires in the horizontal pin and the Black/Yellow wire opposite the horizontal pin on top. HTH.
Old 03-17-2006   #6 (permalink)
DESTEC's Avatar
DESTEC is on a distinguished road
I don't have the drawing in front of me and a socket, but I am sure I would have
drawn the flasher socket as looking down onto it: flasher insert side, that is.
(In my minds eye, I can not 'see' the bottom view of the socket.)
I will check when I get home, as I have a dash IP out and will make a note on the drawing .
If I am not correct in what I am saying here, I will repost Monday.
Note the plug and receptacles of the fuse box, I addressed just that issue there to aid troubleshooting or rewiring.
JJ
DESTEC is offline
Old 03-17-2006   #7 (permalink)
EJprovost's Avatar
Thanks JJ. Oh and it is a three prong, not a two that I wanted to do for a modification. Any sugestions? I understand you have a kit? PM me ok.
"Enjoy The Ride!"
1995 Camaro Z28
1970 GT, 1971 GT
Old 03-18-2006   #8 (permalink)
EJprovost's Avatar
So I take it any 3 prong with the prongs in the right places will work? Does anyone recommend a specific one?
"Enjoy The Ride!"
1995 Camaro Z28
1970 GT, 1971 GT
Old 03-18-2006   #9 (permalink)
Wonderful ....
The indicators on GTs are another of their wonderful 'features' !
I just rounded up several three pronged blinker units from old Rovers and found that a Lucas one worked well.
There are many threads on the subject accessible by putting 'Double Flash' into the search box. This seems to be the most comprehensive one:
http://www.opelgt.com/forums/1c-ligh...t=Double+flash
Old 03-18-2006   #10 (permalink)
EJprovost's Avatar
Thanks Jim. I'll print this out and give it to Ben. He is the one trying to help me untangle the electrical mess at hand. Oh gosh, just looked at that thread, looks like a good one. (Got the problem solved, don't you Ben.)
"Enjoy The Ride!"
1995 Camaro Z28
1970 GT, 1971 GT
Old 03-18-2006   #11 (permalink)
asdasc's Avatar
Moderators, is there a way to put a sticky on that thread? Or put it into a tech article? It is valuable info on a common topic!
Steve
asdasc is offline
Old 03-18-2006   #12 (permalink)
Done. If you run across any other really good threads on the double blink, you can copy the good posts to your PC, and then re-create them as an article.
Old 03-19-2006   #13 (permalink)
EJprovost's Avatar
Speaking of blinker thingy's take a look at what we found. Amazing how all the power had been routed to one side of the fuse box so carefully covering the melted parts. Finally we found one of the gremlins.
"Enjoy The Ride!"
1995 Camaro Z28
1970 GT, 1971 GT
