1971 GT
Unanswered: Wiring gurus - Help
Hopefully this can be a resource for people adding any of these items. I'm hoping that the wiring gurus out there can look it over and point out any errors I may have made. Specifically, I would like to know:
Thanks for your help
Your using the start circuit from switch to pick up the start relay, what is the oil pressure switched used for? Is it just fuel pump safety to kill it on loss of oil pressure. I see you have starter circuit assuming that is only for energizing fuel pump on start (I guess circuit assumes fuel line is charged and bowl is full of gas unless your going to crank it for awhile while pump filling carb with gas) then the switched power on oil switch after starting runs the fuel pump as long as pressure is adequate?
1971 GT
That's the idea. The wiring for this was detailed in a post by Tekenaar. I'm just pulling all this info together.
2. Best bet is to use the same connection for the original "transparent" coil. It went to the #6 fuse male spade lug. IDK what connection you would use to energize the compufire system during start mode, you'd have the check their schematic.
I replaced the org. ign. wire ( clear res. wire from fuse box ) with next size solid wire to power my Compufire sys. because it needs 12volts .
John
Or you can use the clear wire to control yet another relay for your 12 volt input to the compufire module.
What do you think guy ..is there enought voltage to keep the contacts from fluttering sure would pull some current off the fragile ignition switch
Tinkering is my name..fun is the game Last edited by wrench459; 02-06-2008 at 08:26 PM. Reason: questions |
No need to use the resistor wire at all, just run a new one, much better.
Is the relay that the 14ga black running to supposed to be the Otto Start. If it is that is not the proper wire to use, I have to look at a schematic but I believe it is black/red. Yup, black/red ....check here...http://www.opelgt.com/photopost/data..._Schematic.pdf
Jeff '73 GT,5spd,Recaro,EDIS4 2.2 EFI by MegaSquirt, Ali Flywheel w/S10 Clutch, Electric Fan, Roller Rockers, Venolia Pistons, 6 Cyl Intake w/ Custom Injection, 15" Wheels,Lecarra,F&R Sway Bars,Custom Exhaust,1" Sport Spring,Koni Reds,Big Brakes,3 Core Ali Radiator,Hse of Colors Kandy Pagan Gold. 123 WHP @ 6800 RPM ![]() '64 VW Karmann Ghia '08 BMW M3 Last edited by markandson; 02-06-2008 at 10:36 PM. |
#9 (permalink) | |
1971 GT
