Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 1 - Electrical > 1D - Wiring Diagrams
Old 10-13-2008   #1 (permalink)
zinthesky's Avatar
Real Name: Kristopher
zinthesky is on a distinguished road
Unanswered: Where does this wire go?
I was repairing/replacing some wiring under the hood, and found a black wire, with a grey shield over it coming from the wire bundle below the coil. I checked the wiring diagram, and can't seem to locate it. thought it might go to the coil. Thought I should ask before. I trimed the wire back, and added a yellow extension as you can see in the picture below. Any ideas?
zinthesky is offline
Old 10-13-2008   #2 (permalink)
opelspyder's Avatar
Wire
There is a black wire (may have a red tracer-can't remember) that goes through the harness from the starter to the coil, this provides A full 12V while cranking over the engine. This may be your wire. There is another wire that is semi transparent that goes to the coil, this is a resistance wire and it goes to the coil. Then there is a green wire that goes to the distributor and also to the tachometer from the neg side of the coil. I bet it is the starter wire you are in question of
Keith
opelspyder is offline
Old 10-13-2008   #3 (permalink)
GTer
pecje's Avatar
Real Name: Patrick
pecje is on a distinguished road
Look here:
http://www.opelgt.com/forums/1b-igni...-new-post.html
On page 2 of this thread there is an excellent diagram by Tekenaar how to connect all the wires.
Definitely EX-member of the MWTE! © Mr. Corey Suggs
pecje is offline
Old 10-13-2008   #4 (permalink)
Was the vehicle running okay before you started this repair? Since you've peeled back the insulation I guess you're sure the wire is black. What size/gauge do you think it is?
hrcollinsjr is online now
Old 10-13-2008   #5 (permalink)
Check the + side of the coil, there should be a 14G Black wire and a transparent wire hooked up there, as stated earlier. The only other Black wire in that area woulod be a 18G Black wire in the alternator regulator wire bundle of three wires, that also include a fuseable link going to the Blue/White wire to the ammeter warning light. HTH.
Old 10-13-2008   #6 (permalink)
Ron, I thought about this also as it looks like from the picture that's is what it might be except I can't recall ever seeing any of those three wires inside a gray sleeve. I even wondered about it being the temp sending unit wire hence my question about the color.
Old 10-13-2008   #7 (permalink)
zinthesky's Avatar
Temp Wire
It was the Temp sending wire to the Themo housing. Thanks for your help!!!
Old 10-13-2008   #8 (permalink)
Doggone it Harold, you're quite correct. The alternator to regulator is in an asbestos kinda sleeve of woven material. Musta been another session of "old-timer's" disease. Looks like I'm gonna have to read and re-read some of these need help threads closer. Yeah, temp sender wire that goes along the front of the rocker arm cover. Of course not having a 1.9L engine anymore doesn't help either.
