Real Name: Neil
Answered: Fuse Pic/Diagram?
The Factory Service Manual link is not opening in the Opel Tech Center, and I'm trying to troubleshoot my front driver's side turn signal not working. I've tested the bulb, the socket, and the wiring. The wiring doesn't seem to give a consistant read out. I looked at my fuses and non of them looked burned out, but I'm sure it would be good to replace them anyway. |
Most Helpful Answer - Posted by newman27
I scanned this page from the 1972 FSM. I think you can ignore the x'ed out 5 amp fuse replaced with an 8. The 5 is correct I believe even though the part number listed is for the 8 amp fuse?!? Yet another FSM typo (along with the wrong year being mentioned in the first paragraph (1971 instead of 1972). HTH Matt |
#2 (permalink) | |
Car Clubs at Hemmings Motor News
you can use a "torrent" downloader and get it from the link in this thread
http://www.opelgt.com/forums/general...ual-73-gt.html
There was a link to the FSM electrical schematic that was a PDF file last week, in full color and with the gauge wire sizes. I did a search but couldn't find it. You might have better luck.
'72 Opel GT (Sara)
HTH Matt
link is playing up but a google search for
opel fsm torrent gets you a few links to it this is one (e - book)opel fsm 1973.zip (3661005) - Torrent Portal - Free BitTorrent File Download Index and Torrent Search i posted it originally @ Download music, movies, games, software! The Pirate Bay - The world's largest BitTorrent tracker
If the PO used larger fuses (higher Amp numbers), usually means it blew the regular size fuse, due to an electrical defect.
Using a stronger fuse is actually pretty dangerous, as you don't fix the problem. You are allowing much more electricity to flow through the wires and all other components than what they are made for - fire danger !!! Dieter (2) |
I tried to map the current usage of each circuit of the GT.
http://www.opelgt.com/forums/group-1...-fuse-box.html So many projects so little time |
GT Fuses
Here is another list from AutoBooks Opel GT W/shop Manual:
Note that the lights and rear window heater are seperately fused by fuses located on the relays that control them.
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 11-06-2008 at 12:36 AM. |
Site Admin
The FSM is broken down by chapters in the Downloads section. I need to fix that link on the front page.
#13 (permalink) | |
'72 Opel GT (Sara)
Matt
Real Name: Neil
Yes I've noticed those inconsistancies in 5 & 8 amp fuses for fuse number 1.
At least I know now that the previous owner had stuck a bunch of 12, 15, & 25 amp fuses in there that I need to replace soon! |
Fuses #1 & #3
Notice that these two fuses are for higher current electric motors plus the horn and cigar lighter which probably do need the 8 amp fuses ( could even use 10 amp fuses there if eights were not available ...). All the other fuses are for lights or relays of various uses so only need 5 amp fuses.
